Existence and Uniqueness of a solution for ordinary DE
  • Context: Graduate
  • Thread starter Thread starter O.J.
    Existence Uniqueness
The discussion centers on the existence and uniqueness of solutions for ordinary differential equations (ODEs), specifically addressing the initial value problem defined by y' = f(x,y) with y(0) = y_0. It highlights the importance of establishing a general framework where a unique solution can be guaranteed, utilizing the Banach contraction mapping principle to demonstrate this uniqueness. The conversation critiques the lack of proofs provided in educational settings, emphasizing that understanding the foundational theories is essential for applying these concepts effectively.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with the Banach contraction mapping principle
  • Knowledge of fixed point theory
  • Basic concepts of functional analysis, particularly continuous functions
  • Study the Banach contraction mapping principle in detail
  • Explore fixed point theorems and their applications in ODEs
  • Learn about the existence and uniqueness theorems for ODEs
  • Investigate the role of continuity in the context of ODE solutions
Mathematicians, students of differential equations, educators teaching ODE theory, and anyone interested in the theoretical foundations of solution uniqueness in mathematical analysis.
O.J.
I just don't understand the idea behind it. I hate it when they throw these theories at us without proofs or elaborate explanations and just ask us to accept and applym mthem. Anyone care to enlighten me?
Well, sometimes it's hard (or annoying) to find solutions to ODEs by hand and, hence, it is easier to show that there exists a (unique) solution to an initial value problem depending on the information you're given.
However, in a lot of cases, existence/uniqueness is established in an attempt to formulate a general setting in which you are guaranteed to have a solution to an ODE, which is unique.
For example, the classical analysis problem: Show that there exists a solution to [tex]y'=f(x,y)[/tex], [tex]y(0)=y_0[/tex], [tex]\|f(x,y)-f(x,z)\| \le k\|y-z\|[/tex] in some interval [tex][0,a][/tex], where [tex]x\in[0,a][/tex], [tex]y:[0,a]\rightarrow\mathbb{R}[/tex] and [tex]f \in C([0,a]\times\mathbb{R})[/tex].
This could be formulated as a fixed point problem-- i.e. fixed points of:
[tex]Ty=y_0 + \int_{0}^{x}f(t,y(t))dt[/tex], [tex]x\in[0,a][/tex], would satisfy the ODE above.
Hence, one may use the Banach contraction mapping principle after showing that [tex]Ty[/tex] is a contraction mapping (in particular instances), and hence conclude that there exists a unique solution [tex]y[/tex] to the problem [tex]Ty=y[/tex] and hence, existence and uniqueness is established for this class of ODEs. (You would end up with some sort of restriction on [tex]a[/tex] though)
I have no idea why you would be exposed to these sorts of ideas without proofs, since that would sort of defy the purpose.
Quite often, in a physics course, uniqueness of the solutions to Poisson's equation or Laplace's equation are used to find solutions based on guesses and to justify the method of images. Proof is usually deferred.
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 58 ·
