| Thread Closed |
Differential Equations: exact equation |
Share Thread | Thread Tools |
| Sep12-07, 01:31 PM | #1 |
i fell asleep when the professor went over how to solve exact equations :-/ i know it's really easy but despite reading the chapter over and over i still can't get it right. please show me where i'm going wrong / what to do next.
1. The problem statement, all variables and given/known data Determine whether the equation in problem 1 is exact. If it is exact, find the solution. [tex](2x + 3) + (2y - 2)y' = 0[/tex] 2. Relevant equations 3. The attempt at a solution [tex](2x + 3)dx + (2y - 2)dy = 0[/tex] [tex]M_{y} = 0 = N_{x} = 0[/tex] <--- the equation is exact [tex]\psi_{x} = 0[/tex] --> [tex]\psi = \int^x 0dx = x + h(y)[/tex] [tex]\frac{d\psi}{dy} = h'(y) = 2y - 2[/tex] ---> [tex]h(y)= y^2 - 2y[/tex] and then i get stuck. i'm not sure where to go from there. the answer to the problem is [tex]x^2 + 3x + y^2 - 2y = c[/tex], which is apparent to me if you turn the original equation into a separable one, but that's not possible with all exact equations. thanks for your time everyone. |
| Sep12-07, 03:34 PM | #2 |
Recognitions:
An exact equation is one of the form dF(x,y)=0. So it has solutions F(x,y)=c. The dF equation
becomes F_x*dx+F_y*dy=0, where the underscores are partial derivatives. So F_x is your M and F_y is your N. What you want to do is find F. Since F_x=2x+3, F=x^2+3x+h(y). And sure F_y is then h'(y) which you know is 2y-2. Solve for h(y) (as you did). Now what is F? Hence what are the solutions? |
| Jul16-09, 05:59 PM | #3 |
You already solved it. Just plug your c(y) into F. Your F is x^2 + 3x + c(y) after you integrated the M term. Plug c(y) back into F and you get x^2+3x+y^2-2y.
| Jul16-09, 10:18 PM | #4 |
Recognitions:
It's not really worth while recycling threads from 2007. Now is it?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Differential Equations: exact equation
| Exact differential equations | Calculus & Beyond Homework | 4 | ||
| Differential Equations: exact equation | Calculus & Beyond Homework | 0 | ||
| differential equations - exact equations w/ integ factor | Calculus & Beyond Homework | 2 | ||
| Exact differential equations | Differential Equations | 24 | ||
