How Is Centripetal Acceleration Calculated for a Stone Thrown by a Sling?
  • Thread starter Thread starter chaotixmonjuish
    Acceleration
The discussion revolves around calculating the centripetal acceleration of a stone thrown by a sling, specifically focusing on the conditions of the throw, including the sling length and the distance the stone must travel. The problem is set within the context of projectile motion, with considerations for both horizontal and vertical components of motion.
  • Mixed
  • Participants explore the separation of motion into horizontal and vertical components, questioning the assumptions regarding the angle of release and the nature of the circular motion (horizontal vs. vertical). There are discussions about the equations of motion being used and the implications of initial velocities.
There is an ongoing examination of the calculations related to initial velocity and the correct application of kinematic equations. Some participants express uncertainty about their results and seek clarification on the assumptions made, particularly regarding the initial vertical velocity.
Participants note that the problem specifies not to worry about angles, which influences their approach to the calculations. There is also a focus on the distinction between initial vertical and horizontal velocities in the context of the problem.
chaotixmonjuish
You plan to throw stones by using a sling of length 1.5 m which you whirl over your head. Suppose you wish to throw a stone a distance of 24 m. What must be the centripetal acceleration of the stone just before its release if it is to reach this distance? Assume that the release height is 3.0 m.
So from this question, I was able to separate the motion of the stone into x and y.
Xf= X0+Vt
Yf=Yi+Vt-gt^2
so putting them together I get
t= (xf-x0)/vt
yf=yi+V((xf-x0)/vt)-g((xf-x0)/vt)^2
Am I on the right track? I got an intial velocity of 10.2242. I'm not sure. I was told by my teacher to not worry about angles and other things like that.
My first question would be, are you whirling it in a horizontal circle above your head? Or are you whirling it in a vertical plane. If it's the horizontal case, then the amount of time it's in the air is going to be independent of the initial velocity; it'll simply be the amount of time it would be in the air due to free fall from the height you're whirling it at.
In the case that you're whirling it in a vertical plane, then you would have to worry about the angle (you'd want something around 45 degrees to achieve the maximum distance at the lowest velocity.) But, since you were told not to worry about degrees, I'm guessing that it's the first case.
It's a horizontal circle. What i posted is something he put on the board to help us. I'm just wondering if anyone else got a calculation close to mine
Yes, you are on the right track... find the initial velocity first... but that's not what I'm getting for initial velocity:
Yf=Yi+Vt-gt^2
you need (1/2)gt^2 here...
Hmm...how far off am I
I'm still getting 10.2242
I'm not getting that... can you show the calculations in more detail?
0=3+V((24)/v)-4.9((24)/v)^2
and that yielded 10.2242
Xf= X0+Vt
Yf=Yi+Vt-gt^2
"Yf=Yi+Vt-gt^2" is wrong.
this should be
Yf=Yi-(1/2)gt^2
The initial vertical velocity is 0.
Okay, so would I solve for T in the X equation and plug it into the Y one.
I got 78.0047, and that was also a wrong answer.
can you show your calculation?
0=3-4.9((24)/v)^2
What do you get when you solve the above?
0=24-(1/2)(9.8)(24/v)^2
wrong equation... see my previous post. The 24 should be a '3'.
I kept plugging x positions into the y-coordinates
could you explain to me why the intial velocity is zero
initial vertical velocity is 0... not total velocity... what number did you get?
Also note... the question asks for the centripetal acceleration, not the initial velocity. You need the initial velocity... then from that get the centripetal acceleration.
i got 30.672, the answer was right
I'm just not sure why the intial velocity is zero. I mean the rock is spinning.
initial vertical velocity = 0... initial horizontal velocity = 30.672... it is spinning horizontally, not vertically.
  • · Replies 24 ·
