Calculating Flux in Box with Charged Boards
The discussion revolves around calculating the charge within a box located between two infinite charged boards, with a specific charge density distribution given. The problem involves understanding the effects of the electric fields generated by the boards and the spatial charge density on the total charge within the box.
  • Participants explore the relevance of the electric fields from the charged boards in relation to the charge calculation within the box. There are discussions about whether to consider the fields from the boards or focus solely on the charge density within the box. Questions arise regarding the limits of integration based on the box's dimensions and position.
Participants are actively discussing the setup of the integral needed to calculate the total charge within the box. Some have provided guidance on the integration limits and the interpretation of the charge density, while others are clarifying the relationship between the box's dimensions and the charge density function.
There is a focus on the specific charge density function and the geometry of the box, which is centered at the origin. The discussion also touches on the implications of the boards' positions relative to the box and the assumptions made about the fields involved.
yevi
2 infinite boards placed in space in x =5 and x = -5, charged with unformed positive density [tex]\sigma[/tex] , between those boards is a spatial distribution of charge [tex]\rho[/tex] given: [tex]\rho[/tex](x,y,z)=Ax^2 , A const.
There is no charge outside the boards.
I need to calculate the charge in a box with a side=4, located in (0,0,0) parallel to axis.
I want to approach it using gauss. For this I need to find the flom through the box.
My first question:
Does the fields generated by the boards effect the box or they negate each other and only the spatial field effects?
This just seems to be a straight integration problem... integrate charge density over the volume to get the charge... you don't need the flux...
Ok, no flux.
What about my qustion, do I skip the fields from boards?
All you need to do is find the total charge within the box. No need to worry about fields from outside (or inside!) the box. Are the boards in the box? If not, their charges don't count.
The integral is from 0 to 4?
That depends on where the box is located. If it extends from (0,0,0) to (4,4,4), then yes.
Actually it's center in (0,0,0) so my integral should be from -2 to 2?
That sounds right to me.
I get this:
[tex]\int_{-2} ^{2}(64Ax^2)[/tex]
But the answer is:
[tex]\frac{256A}{3}[/tex]
yevi said:
I get this:
But the answer is:
Your integrand is wrong. can you show how you got that integral?
you mean 64? volume of box... side=4...
the integrand is Q.
[tex]\rho[/tex](v) = [tex]\frac{dq}{dv}[/tex]
Take a slice at a particular x... the volume of the slice is 4*4*dx... so what's the charge contained in this slice...
GOT IT.
Thanks again.
  • · Replies 26 ·
