Post length vs. size of base plate?
The discussion centers on determining the appropriate size of a base plate for a post supporting a 30lb weight positioned 50 inches above the ground. A simple formula for calculating the necessary base plate size is not provided, as the stability of the post is influenced by various factors beyond just weight. The consensus is that without external forces, a base plate is unnecessary, but practical applications require consideration of stability and tipping risks.
  • Understanding of basic physics principles related to torque and stability
  • Knowledge of material properties and weight distribution
  • Familiarity with construction standards for post installations
  • Experience with calculating load-bearing capacities
  • Research methods for calculating torque and stability for vertical structures
  • Explore guidelines for base plate dimensions in structural engineering
  • Learn about material selection for base plates and their impact on stability
  • Investigate best practices for securing posts in various environmental conditions
Engineers, construction professionals, DIY enthusiasts, and anyone involved in structural design or installation of posts and supports.
azcr2k
For some reason I'm having issues today figuring out what size base plate to make for a post that has a 30lb wieght at 50" from the floor? Does anyone have a simple formula? I just want to post to not tip over without any outside forces acting on it. Thanks.
Welcome to PF, Azcr.
It's a bit more complicated than you indicate. If there were no forces at all acting upon it, you wouldn't need any plate.
9K
  • · Replies 43 ·
  • · Replies 33 ·
10K
  • · Replies 27 ·
  • · Replies 27 ·
