DC Generator Question: How Can Loading Occur When Terminals are Open?
The discussion centers on the operation of a DC generator and the phenomenon of loading when the terminals are open. It is established that torque in a DC generator is proportional to the current flowing through its terminals. Even with open terminals, the generator experiences loading due to back EMF, which generates a measurable torque despite the absence of current flow. The key takeaway is that while shorting the terminals maximizes current and torque, open terminals still result in mechanical loading due to internal resistance and back EMF effects.
  • Understanding of DC generator principles
  • Knowledge of back EMF in electrical machines
  • Familiarity with torque and current relationships in motors and generators
  • Basic concepts of electrical power and internal resistance
  • Research the effects of back EMF in DC motors and generators
  • Study the relationship between torque and current in electrical machines
  • Learn about internal resistance and its impact on generator performance
  • Explore the principles of power generation and load characteristics in DC systems
Electrical engineers, students of electromechanical systems, and anyone interested in the principles of DC generators and their operational characteristics.
TheAnalogKid83
I've had this question going in my mind for probably half a year, but I just have not had time to think about it too closely, so maybe someone with experience can help me.
With a DC generator, it's torque is proportional to the current flowing through the input terminals. Basically the voltage applied creates current flow through the internal circuit of the motor, and then this current is converted by a constant to a torque, which is then converted through a friction and inertia transfer function to give you angular velocity of the motor shaft. The key point to my problem is that there is no open at the terminals, and the current has a path to flow.
Now with a generator, you basically have a reversed motor. The physical force is generating electrical engergy. So the turning of the shaft should generate a voltage on the terminals, the back EMF. If you short the terminals, you have maximum current flowing through the generator, and thus a maximum torque. The loading on the physical force should increase greatly when you short the terminals. The open terminals should have 0 torque, and the load should be purely mechanical (friction at steady state). Is this the case? When turning the generator that has open terminals, there still feels like the motor is generating negative feedback, and there still is measurable loading.
I've never had an electro mechanical course, so maybe I am sounding ignorant, but how can you have a loading on the physical force acting on a generator when the terminals of the generator are open and there is no current flow?
That is your problem. It requires both voltage and current to produce power. If you short circuit a generator, it makes no external power. However, the ##I^2R## losses internally soar because of the high current.
  • · Replies 38 ·
  • · Replies 37 ·
9K
  • · Replies 26 ·
  • · Replies 18 ·
