Calculating Minimum Asteroid Size for Astronaut Safety
  • Thread starter Thread starter ColdFusion85
    Asteroid Astronaut
The discussion revolves around calculating the minimum size of an asteroid to ensure astronaut safety during exploration, specifically addressing the conditions under which an astronaut could jump from its surface without floating away into space. The problem involves concepts of density, mass, and gravitational effects on different celestial bodies.
  • Participants explore the relationship between the astronaut's jumping ability on Earth and the implications for jumping on an asteroid. Questions arise regarding the significance of the astronaut's mass and the density of the asteroid in determining its size. Some participants also question the relevance of the given jump height and how it relates to escape velocity.
The discussion is actively exploring various interpretations of the problem, particularly how to connect the astronaut's jump height on Earth to the conditions on the asteroid. Participants are questioning assumptions about mass and gravitational effects, and some guidance has been offered regarding the relationship between velocity and escape velocity.
There is an assumption that the asteroid's mass is significantly larger than the astronaut's, which raises questions about the implications of this assumption on the calculations. Additionally, the problem does not specify the shape of the asteroid, which may affect the calculations being discussed.
ColdFusion85
Sorry guys, one more question for now. It is the only other one I couldn't really get on this homework assignment.
An astronaut is about to explore an asteroid of average density [tex]\rho[/tex]=5000 kg/[tex]m^3[/tex]. He is worried that he may accidentally jump from its surface and float off into space. How big (what diameter) must it be before he can neglect this possibility? The astronaut knows that his mass, m, including space suit, is 91 kg. He also knows that on the Earth he can raise his center of gravity 0.6 m by jumping with his space suit on. It seems reasonable to assume that the maximum energy output of his legs will be the same on the asteroid as on the earth. For simplicity assume M>>m, such that M does not move significantly during the action, and then check this assumption [How much does the asteroid move relative to the astronaut?].
[tex]\rho = m/V[/tex]
V = 4/3[tex]\pi[/tex][tex]r^3[/tex]
I figure if I can get the mass of the asteroid I can calculate the radius, and hence, the volume. I am not sure what clue the 0.6 m jumping on Earth is supposed to give me. Also, why is m of the astronaut given if we can neglect it, since M>>m?
oops, I meant to say "calculate the radius, and hence the diameter". Also, I am not sure now why I included V, as it doesn't say anything about the asteroid being spherical.
Regarding the 0.6 m jump on the Earth: What does this translate to in terms of velocity? Do you know what escape velocity is?
I'm not sure...I know escape velocity is [tex]\sqrt{2GM}/R[/tex]
The astronaut changes his velocity from 0 to some value to enable him to jump 0.6 m into the air on the Earth. He will get this same "delta-V" on the asteroid. (That's one of the givens.) So relate that to escape velocity.
