Thread Closed
Does the sum of the mass of two bodies vary with the distance between them ?
Share Thread Thread Tools
Sep14-07, 03:16 PM   #1
Say we have 2 bodies of m1 , m2 .
The distance between them is
a) r1 Ma=m1+m2
b) r2>r1 Mb=m1 +m2
In each case the mass was measured by an inertial observer . Is it true that Ma<Mb
I saw this kind of thinking in measuring the energy neccesar to separate a nucleon from a nucelous . It said that a nucleus mass is less than the mass of the component nucleons added .
I only read special relativity . Is this a general relativity case ?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Sep14-07, 07:48 PM   #2
Quote by C_Ovidiu View Post
a) r1 Ma=m1+m2
b) r2>r1 Mb=m1 +m2
Suppose that two bodies [itex]m_1[/itex] and [itex]m_2[/itex] are at rest and there is interaction between them with potential energy [itex]V(r)[/itex] . Then the total energy of the system is
[tex] E(r) = m_1c^2 + m_2c^2 + V(r) [/tex]
and the total mass
[tex] M(r) = E(r)/c^2 = m_1 + m_2 + V(r)/c^2 [/tex]
If the interaction is attractive [itex]V(r) < 0[/itex], then the total mass of the system is less than the sum of masses of its constituents. These rules are valid for all kinds of interactions: electromagnetic, nuclear, and (I believe) gravitational as well.
Eugene.
Sep14-07, 09:37 PM   #3
Recognitions:
Retired Staff Staff Emeritus
a) r1 Ma=m1+m2
b) r2>r1 Mb=m1 +m2
Basically, the answer is yes, though it turns out that GR defines more than one type of mass.
See for instance This wiki article or this one
for some of the details on defintions of mass in GR. (Note also that I wrote the second article above).
If you use the appropriate GR defintion of mass (say the ADM mass), then if you separate m1 and m2, you can measure their individual masses in isolation (as long as they are in asymptotically flat spacetimes so that the ADM mass concept applies).
Then one can allow m1 to approach m2, and keep the assumption that spacetime is asymptotically flat so that the ADM concept applies. The mass of the system, m_total, will then be lower than m1 + m2, and for weak fields m_total - m1 - m2 will be a negative number equal to the Newtonian binding energy of the system.
Thread Closed
Thread Tools
Similar Threads for: Does the sum of the mass of two bodies vary with the distance between them ?
Thread Forum Replies
Max distance betw 2 retarding bodies moving towards each other,so that they meet. Introductory Physics Homework 1
velocity with mass and distance given ? General Physics 4
Mass vs distance General Physics 19
mass of stellar bodies Introductory Physics Homework 4
Mass vs distance General Physics 20
