Understanding Variational Calculus: A String Theory Question
The discussion revolves around a variational calculus problem related to string theory, specifically examining the equation involving variations of the Lorentz invariant spacetime distance. Participants are exploring the implications of the delta notation and its relationship to derivatives.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are attempting to understand the distinction between the delta notation and differential notation, questioning whether it is appropriate to treat delta as a derivative. There are discussions about the implications of approximations and the conditions under which certain terms can be ignored.
The conversation is ongoing, with participants providing insights into the differences between delta and differential notation. Some guidance has been offered regarding the treatment of variations, but confusion remains about the application of these concepts in more complex scenarios.
There are indications that participants are grappling with the nuances of variational calculus and the assumptions underlying the use of delta notation, particularly in the context of small variations. The discussion reflects a need for clarity on how to handle multiple terms in variations.
ehrenfest
I saw the following equation in my (Zwiebach page 83).
[tex]2 ds \delta (ds) = \delta (ds) ^2[/tex]
where delta is the variation from variational calculus and ds is the Lorentz invariant spacetime distance.
It seems like they took a derivative from the right to the left but I am really not sure why you can do that because I thought delta was just a very small variation function.
The delta notation means "change of" which is the same as derivative. If it makes you feel better, replace delta with delta/ dx and then multiply by dx on both sides to remove it. Seems a bit sketchy, but it works as long as the variation is small, which of course is the point of derivatives in the first place.
So, in this case it makes the most sense to replace delta by d/ds, right? That does seem sketchy.
It's not sketchy. d and delta are two different things. d refers to the differential of s(t) with respect to a parameter as in s(t)->s(t+epsilon). delta refers to the variation of some functional with respect to the variation of s(t) by a arbitrary function. s(t)->s(t)+epsilon*r(t).
As Dick wrote, d and [itex]\delta[/itex] are not the same thing. ds as it is said, is the ghost of a departed quantity, while [itex]\delta s[/itex] is a boring old number.
[itex]2dsd(ds) = d(ds)^{2}[/itex] is an exact equation.
[itex]2 ds \delta (ds) = \delta (ds) ^2[/itex] is approximate. To be exact, it should be
[itex]2ds \delta(ds) + \mathcal{O}((\delta ds)^2) = \delta (ds) ^2[/itex]
In this case, you are expected and indeed required to use only such [itex]\delta[/itex] as to make [itex]\delta^2[/itex] small enough to ignore.
Sorry--I encountered this again and I am still confused about it. When you say replace delta by delta/ds (and then multiply both sides by ds), do you mean that I should treat this as the derivative operator with respect to ds? But can you do that if there is more than just one term in there (say [tex]\delta (dx dy dz) ^2[/tex])? How do you think of it then?
  • · Replies 76 ·
