Dark Energy as a Gravitational Field?
The discussion explores the possibility of modeling dark energy as a gravitational field that increases with distance, particularly in relation to the Hubble redshift and the structure of the universe. Participants examine theoretical implications and the nature of gravitational effects in cosmology.
  • One participant proposes that dark energy could be modeled as a gravitational field emanating from the edges of the universe, suggesting that this field causes objects to accelerate away from each other.
  • Another participant raises a concern that this model may conflict with the homogeneity of the universe, noting that there would be more matter at greater distances from the Hubble center.
  • Some participants argue that the apparent abundance of galaxies at the edge of the Hubble radius supports the idea of greater matter at those distances, while also considering the implications of looking back in time when the universe was smaller.
  • A participant mentions that any gravitational field from the Hubble sphere would have no effect due to spherical symmetry, questioning the validity of the proposed model.
  • There is a discussion about the relationship between redshift and gravitational potential, with one participant suggesting that the increasing redshift observed with distance could indicate that the universe is climbing out of a gravitational well over time.
Participants express differing views on the implications of modeling dark energy as a gravitational field, with some supporting the idea and others raising concerns about its consistency with observed cosmic structure. The discussion remains unresolved, with multiple competing perspectives present.
Participants note the need for relativistic methods in calculations related to redshift and gravitational effects, highlighting the complexity of the topic and the potential for varying interpretations based on different assumptions.
cefarix
I've been wondering, is it possible to model both the Hubble redshift and dark energy as a gravitational field which gets strong the further away you look? For example, we know that light from distant galaxies is red-shifted, which is equivalent to a photon having climbed out of a gravitational potential well. At the same time, since the light coming to us from these distant objects is all from the past, we could treat the past as a gravitational well. So, increasing distance and increasing past having higher gravitational attraction. If everything sits in a gravitational well which always increases as you look further out, and if the cause of this gravitational well is the fact that the universe was smaller before, then it would appear that everything would always be attracted to the edge of the universe, and that this attraction would increase over time because there would be more past behind us.
So, I guess, the question is, can dark energy be modeled as a gravitational field coming from the "edges" of the universe, causing objects to accelerate ever faster away from each other?
Another example is take a black hole. Things are attracted to the event horizon, but suppose we turn it inside out. The objects are inside the black hole now, but they are repelled from the singularity and attracted to the event horizon.
This would seem to conflict with the homogenuity of the universe - there would be more matter at great distance from the Hubble center.
There is however an interesting aspect to uniform radial dilation of a spherical volume - both the surface area and the volume must accelerate
Isn't greater matter at great distance from the Hubble center what we see? We find far more galaxies at the edge of Hubble radius than we do in the local vicinity.
If you mean the limits of the Hubble sphere, any field coming from there would have no effect because of the spherical symmetry.
But we are looking back in time - when the universe was smaller - more galaxies per unit volume
Mentz114:
Right, there would be no accelerative effects, but the calculations have to be made using relativistic methods. There would definitely be red-shift, which again could be perceived as galaxies receding from each other.
yogi:
That's my point, kind of. The more to the past we look, the greater red-shift we see. So can it not be construed that the universe is climbing out of a gravitational potential well as it goes from past to future? And by virtue of the fact that it takes time for information to travel across space, the farther out we look, the deeper we see this gravitational well to be (the greater the red-shift), so the gravitational well could also be seen as increasing with increasing distance in space.
Now, I think, actual acceleration may not be important. What is needed is that the red-shifting of the galaxies we see increases, not just with distance from us, but also with the passage of time.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 16 ·
