Electric Field of an Insulating Cylindrical Shell
  • Thread starter Thread starter Winzer
    Cylindrical Shell
The discussion revolves around the electric field and potential of a long cylindrical insulating shell with specified inner and outer radii and a constant charge density. Participants are exploring the electric field at various distances from the axis and the potential at the outer radius.
  • Mixed
  • Participants discuss using Gauss's law and integral calculus to determine the electric field and potential. There is confusion regarding the correct application of formulas and the integration process, particularly in relation to charge density and the geometry of the cylindrical shell.
There are multiple lines of reasoning being explored, with some participants questioning assumptions about charge distribution and the limits of integration. Guidance has been provided regarding the use of Gauss's law and the need to consider how charge varies with distance.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an ongoing discussion about the implications of the charge density and the geometry of the insulating shell.
Winzer
A long cylindrical insulating shell has an inner radius of a = 1.38 m and an outer radius of b = 1.61 m. The shell has a constant charge density of 4.80 C/m3.
1. What is the magnitude of the electric field at a distance of 1.87 m from the axis?
2. What is the magnitude of the electric field at a distance of 1.51 m from the axis?
3. If we take the potential at the axis to be zero, what is the electric potential at the outer radius of the shell?
[tex]E=\frac{kq}{r^2}[/tex]
[tex]\oint \vec{E}\vec{dr}= \frac{Q_{Enclosed}}{\epsilon_{o}}[/tex]
For 1 i use [tex]E=\frac{kq}{r^2}[/tex] but i am confused on finding q because i am given density of c/m^3. I am assuming an infinity long cyclinder?[tex]\vec{}[/tex]
careful.. the integral should be E.da, not E.dr
Take a cylindrical section of arbitrary length L...
You are correct dA.
So:
[tex]dE= \frac{kdQ}{r^2}, dQ=pdV \longrightarrow dQ= 4.80 C/m^3 * 2\pi r l dr[/tex]
Then:
[tex]E= \int \frac{k 4.80* 2 \pi r l}{r^2}dr[/tex]
With he boundries a=a b=b
Winzer said:
Then:
No... use gauss' law... what is your gaussian shell... what is the charge enclosed...
Oh of course..I would pick a cyclinder as my G surface.
exactly. can you write out the integral using gauss law for the first part? we need the field 1.87 m away.
Ok, thanks. i got 1 & 2.
how about 3?
I know [tex]V=\frac{kq}{r}[/tex]
Winzer said:
how about 3?
Nah... I don't think that'll work...
The voltage at r minus the voltage at 0 is:
[tex]-\int_0^r{\vec{E}\cdot\vec{dr}[/tex]
You need to integrate this from 0 to b=1.61...
But then i get a ln(r/0), with other stuff infront. ln is -inf?
That doesn't look right... the integral from 0 to 1.38m is 0... because the field is 0 for this part... so you just need the integral from 1.38 to 1.61.
so does:
[tex]V=\frac{-p (b^2-a^2)}{2 \epsilon_{o}}ln(\frac{b}{a})[/tex]
sound on the right track?
Winzer said:
so does:
Hmm... I'm getting something different. Can you show how you got that integral?
Well how should I do it?
Get the field inside the insulator. Then do [tex]-\int_{1.38}^{1.61}\vec{E}\cdot\vec{dr}[/tex]
What do you get for the field in terms of r?
Use gauss' law. [tex]4.80*{\pi}r^2h = 2{\pi}rh*E[/tex]
mmm.. i Think it should be [tex]E= \frac{-p(b^2-a^2)}{2r \epsilon_{o}}[/tex]
I choose [tex]-p(b^2-a^2)=Q_{enclosed}[/tex] because i had to integrate to find the charge enclosed.
But the charge enclosed changes with r. You're integrating from r = 1.38 to 1.61... as you increase r, the charge enclosed becomes bigger.
so b is replaced with r
Ah... yes, you're right... I made a mistake in my post. I should have written:
[tex]4.80*{\pi}(r^2 - a^2)h = 2{\pi}rh*E[/tex]
So that gives what you have by replacing b with r.
ok, cool I got it. I just made the mistake of not letting charge vary with r.
  • · Replies 17 ·
