| Thread Closed |
Relativistic Electron |
Share Thread | Thread Tools |
| Sep15-07, 11:58 PM | #1 |
a) What potntial difference will accelerate an electron to the speed of light according to classical physics? b) With this potential difference, what speed will the electron acheive relativistically? c) What is the relativistic mass at that speed? d) What is the relativistic kinetic energy? 2. Relevant equations see solution 3. The attempt at a solution a) [tex]q_{e} \Delta V = \Delta K = \frac{1}{2}m_{e}c^{2}[/tex] [tex]\Delta V =\frac{m_{e}c^{2}}{2q_{e}}=255,499 Volts[/tex] b) here i'm assuming that i can say (is this assumption valid??): [tex]q_{e} \DeltaV = \gamma m_{e}c^{2}-m_{e}c^{2} [/tex] then solve for [tex]\gamma[/tex], [tex]\gamma=\frac{q_{e}\DeltaV}{m_{e}c^{2}}+1[/tex] the velocity follows immediately c) [tex]m = \gamma m_{e}[/tex] d) here's where I get confused, if i calculate kinetic energy using: [tex]K=\gamma m_{e}c^{2}-m_{e}c^{2}[/tex] I get the same kinetic energy ([tex]q_{e} \Delta V [/tex]) I assumed in part b (obviously)... now this makes some sense to me, in the respect that the classical kinetic energy at the speed the electron would obtain relativistically is lower than this, but it is also equal to [tex]\frac{1}{2}m_{e}c^{2}[/tex]... i don't think this is a contradiction, but it seems strange... is my underying assumption in part b wrong? |
| Sep16-07, 01:20 AM | #2 |
Recognitions:
| Sep16-07, 02:47 AM | #3 |
Great, thanks... I looked at it quite a few times, and couldn't figure out how it could be wrong, but it seemed too convenient... I have another quick question actually if you don't mind...
A different problem is looking at a particle decay in the center of momentum frame (S) and the laboratory frame (S')... It gives me the total energy of the parent particle,[tex]E_{total}= 498 MeV[/tex], and the individual rest energies of the daughter particles, 135 MeV each. The particle decays at some point, and the two daughter particles leave w/ energy and momentum [tex]p_{1},E_{1}[/tex] and [tex]p_{2}, E_{2}[/tex]. In frame S, the parent particle is at rest. In frame S' it moves with a velocity of [tex]v = \frac{3c}{5} [/tex], and the daughter particles have energies and momenta [tex]E_{1}',p_{1}'[/tex] and [tex]E_{2}',p_{2}'[/tex]. For the S frame, (I've assumed that they energies/momenta were equal) and said that: [tex] E_{total}=E_{1}+E_{2}=2E_{daughter} [/tex] Then obtained the momentum for each from: [tex] E^{2}=(pc)^{2}+(m_{0}c^{2})^{2} [/tex] For the S' frame, I'm thinking that if I find the velocities of each particle with respect to S' using the Lorentz velocity transform, I can use that velocity to find the momentum via: [tex] p=\gamma m_{0} u_{S'} [/tex] where u will be velocity relative to S'... Now, if I am looking at the situation the right way, I will have a different [tex]\gamma[/tex] for each of the particles when figuring their momentum in S'. So for the momentum of particle 1, I'll have: [tex] p_{1}=\frac{m_{0}u_{S'}}{\sqrt{1-(\frac{u_{S'}}{c})^{2}}}[/tex] Would that be correct? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Relativistic Electron
| What is the velocity of a relativistic electron? | General Physics | 25 | ||
| Electron Proton Collisions and Electron Capture | Introductory Physics Homework | 1 | ||
| Relativistic Electron Wave | Introductory Physics Homework | 1 | ||
| relativistic and not relativistic motions | Special & General Relativity | 2 | ||
