Finding Null Space of a Matrix with Trigonometric Equations
  • Thread starter Thread starter indigojoker
    Null space Space
The discussion revolves around finding the null space of a matrix involving trigonometric functions and complex exponentials. The original poster presents a system of equations derived from the matrix equation set to zero, expressing uncertainty about how to solve for the variables involved.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss methods for solving linear systems, with some suggesting substitution as a technique. There is a focus on the nature of the solutions, including the trivial solution and the potential for free parameters. Questions arise about the independence of the equations and the implications for the solution set.
Participants are actively engaging with the problem, exploring different approaches to finding the null space and eigenvectors. Some guidance has been offered regarding the nature of the solutions and the relationship between the equations, but no consensus has been reached on a definitive method or outcome.
There is an emphasis on the potential for multiple interpretations of the equations and the need to consider the implications of dependent equations in the context of the null space and eigenvalue problems.
indigojoker
I need to find the null space of:
[tex]\dotx \left(\begin{array}{cc}cos(\beta)-1&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)-1\end{array}\right)[/tex]
so:
[tex]\dotx \left(\begin{array}{cc}cos(\beta)-1&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)-1\end{array}\right) \binom{x}{y} = 0[/tex]
I'm not sure how to go about doing this because I've been staring at:
[tex](cos(\beta)-1)x=-sin(\beta)e^{-i \alpha} y[/tex]
[tex]sin(\beta) e^{i \alpha} x = (-cos(\beta)-1) y[/tex]
for a while now and I'm not sure how to get the x and y values
It's just a linear system of equations, isn't it? How do you normally solve systems of linear equations?
by substitution, but the thing is I keep getting y=0 and x=0
Does the obvious [tex]x = -sin(\beta) e^{-ia}, y = cos(\beta)-1[/tex] not work?
sure, but i would like to know how to solve for that.
so:
Usually when you solve a problem like this-- i.e. a homogeneous linear system, you're going to end up with the trivial solution (x,y)=(0,0) and a surplus of other solutions with a free parameter.
What you usually do is solve one of these equations and use a variable as a parameter.
For example, if you solve the first equation you've been staring at for [tex]x[/tex], you get:
[tex]x=-\frac{sin(\beta)e^{-i \alpha}}{cos(\beta)-1}y[/tex]
And hence, you have [tex]\binom{-\frac{sin(\beta)e^{-i \alpha}}{cos(\beta)-1}y}{y}[/tex] as your null-space, y being a free parameter.
You could have just as well have done it for x, with that as the free parameter.
Ofcourse, you could always simplify this.
You can do similarly for the second equation you got and obtain a basis for your null space.
Notice that the two equations are not independent, so the solution, if one exists, would be a line. Such a line has to include the origin, so just eliminate/ignore one of the equations, and what you've got left should describe the line.
thanks for the advice!
In the grand scheme of things, I was trying to find the eigenvectors of:
[tex]A=\dotx \left(\begin{array}{cc}cos(\beta)&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)\end{array}\right)[/tex]
I got eigenvalues of +1 and -1
if we took the -1 case, we have:
[tex]\dotx \left(\begin{array}{cc}cos(\beta)+1&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)+1\end{array}\right) \binom{x}{y} = 0[/tex]
my null space would be:
[tex]x=\binom{-sin(\beta)}{(cos(\beta)+1)e^{i \alpha}}[/tex]
However, this does not satisfy the eigenvalue equation: Ax=x[tex]\dotx \left(\begin{array}{cc}cos(\beta)-1&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)-1\end{array}\right) \binom{-sin(\beta)}{(cos(\beta)+1)e^{i \alpha}}=\binom{sin(\beta)}{(-cos(\beta)-1)e^{i \alpha}}[/tex]
Not sure what this means
It looks correct to me... The relevant equation is not Ax=x, but Ax = ax, where a is the eigenvalue.
  • · Replies 18 ·
