Speed of Light: Can We Go Faster?
The discussion revolves around the possibility of light traveling faster than its established speed, exploring theoretical ideas, implications of special relativity, and the nature of vacuums. Participants also consider whether anything can exceed the speed of light and the implications of changes in the speed of light in different contexts.
  • Some participants propose that theoretically "throwing" the source of light could make it travel faster, though this idea is considered unrealistic.
  • Others argue that according to special relativity, the speed of light remains constant regardless of the motion of the source.
  • A participant questions whether anything can travel faster than light, with some asserting that no object or particle can do so in a vacuum.
  • There is a suggestion that the speed of light could potentially vary in different vacuums, but this is met with skepticism regarding its significance.
  • A quote from John Barrow is shared, discussing how changes in fundamental constants like the speed of light might not be meaningful if dimensionless constants remain unchanged.
  • Some participants express frustration over recurring discussions about changes in the speed of light without considering how such changes could be detected.
  • A later reply introduces the idea that beyond the universal event horizon, spacetime may move faster than light relative to observers.
Participants express a range of views on the possibility of exceeding the speed of light, with some asserting it is impossible while others explore theoretical scenarios. The discussion remains unresolved with multiple competing perspectives.
There are limitations regarding the assumptions made about vacuums and the implications of changing the speed of light, as well as the speculative nature of some claims made in the discussion.
N468989
is it possible to make light travel faster than the actual speed of light? an unrealistic idea is to "throw" the source of light in the direction of the emitting beam...theoretically it must work.
another question does anything travel faster than light?
Science news on Phys.org
Not according to currently accepted physical theory (special relativity). The speed of light is the same with respect to any frame, regardless of the speed of the source.
No.
Good link. But no "thing" (object or particle) travels faster than light.
In vacuum. :wink:
neutrino said:
In vacuum. :wink:
D'oh! You got me! :-p
I heard somewhere that you could lower the amount of energy in a vacuum and the speed of light itself could potentially raise by a fraction.
Not all vacuums are the same. The measure speed of light is currently only observed in one vacuum.
It wouldn't change much though...
Not all vacuums are the same. The measure speed of light is currently only observed in one vacuum..
Would you like to make an exact citation on where you "heard" this from? Keep in mind of the speculative post no-no that is explicitly stated in the PF guidelines.
Zz.
i just get tired of seeing this recur so often without people wondering if any such change in c can even be meaningful. as if we would know the difference.
quoting John Barrow:
[An] important lesson we learn from the way that pure numbers like [itex]\alpha[/itex] define the world is what it really means for worlds to be different. The pure number we call the fine structure constant and denote by [itex]\alpha[/itex] is a combination of the electron charge, e, the speed of light, c, and Planck's constant, h. At first we might be tempted to think that a world in which the speed of light was slower would be a different world. But this would be a mistake. If c, h, and e were all changed so that the values they have in metric (or any other) units were different when we looked them up in our tables of physical constants, but the value of [itex]\alpha[/itex] remained the same, this new world would be ''observationally indistinguishable'' from our world. The only thing that counts in the definition of worlds are the values of the dimensionless constants of Nature. If all masses were doubled in value [including the Planck mass mP ] you cannot tell because all the pure numbers defined by the ratios of any pair of masses are unchanged.
i just wish people would ask: "how would we ever know that the speed of light has changed? ... changed relative to what??"
Someone actually posted a question on similar lines, recently...
https://www.physicsforums.com/showpost.php?p=1421517&postcount=5
The accelerating cosmos infers that beyond the universal event horizon, unobservable spacetime moves faster than light speed relative to us.
See also the (speculative) book Faster Than Light: Superluminal Loopholes in Physics (Plume) by Nick Herbert.
13K
  • · Replies 19 ·
  • · Replies 19 ·
