Thread Closed
Newtons Laws
Share Thread
Sep16-07, 12:16 PM   #1
Newtons Laws
A ball of mass M is suspended by a thin string (of negligible mass) from the ceiling of an elevator. The vertical motion of the elevator as it travels up and down is described in the statements below. Indicate for each of the situations described the relation between value of the tension in the cable, T, and the weight of the ball, Mg, or whether one Cannot tell.
(Assume that there is no air, i.e., neglect the buoyancy effect of the air.)
The elevator is traveling upward and its upward velocity is decreasing as it nears a stop at a higher floor.
The elevator is traveling downward and its downward velocity is decreasing as it nears a stop at a lower floor.
The elevator is stationary and remains at rest.
The elevator is traveling upward and its upward velocity is increasing as it begins its journey towards a higher floor.
The elevator is traveling upward at a constant velocity.
The elevator is traveling downward and its downward velocity is increasing
3. The attempt at a solution
1. T>mg
2. T>mg
3. T=mg
4. T<mg
5. T=mg
6. T<mg
Where am I going wrong? My answers are not right, but I am not sure where my mistake(s) are.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Sep16-07, 12:21 PM   #2
Draw diagrams showing a ball and three things: the tension, the weight, and the acceleration. Apply newton's 2nd law F=ma and try to deduce the relations.
Sep16-07, 12:32 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Take the first one:
In this case, acceleration is DOWNWARDS, in the direction of the force of gravity.
Now, does that mean the upwards tension force is greater or less than the weight of the mass?
Sep16-07, 12:39 PM   #4
Newtons Laws
less than
Sep16-07, 12:41 PM   #5
Recognitions:
Quite so!
Now, give an argument as to why you think 2. is correct.
Sep16-07, 12:44 PM   #6
because the acceleration is acting upwards, opposite of gravity so the tension force would be greater
Sep16-07, 12:46 PM   #7
Recognitions:
Correct!
Now, study your other answers, present your arguments for your view; you are allowed to change your mind if you think you made some mistake earlier.
Sep16-07, 12:47 PM   #8
Thank you!
Sep16-07, 12:47 PM   #9
Recognitions:
You are not finished..
Sep16-07, 12:51 PM   #10
I know I am working on them... I know the third has to be equal and the 4th I think T would be greater because it is accelerating upwards, opposite of gravity
Sep16-07, 12:53 PM   #11
Recognitions:
Quote by BuBbLeS01 View Post
You are right; only a "surplus" of tensile force can yield upwards acceleration.
The other relations are right.
Sep16-07, 12:58 PM   #12
okay thanks so much!
Thread Closed
Similar discussions for: Newtons Laws
Thread Forum Replies
newtons laws Introductory Physics Homework 3
newtons laws Introductory Physics Homework 2
Newtons Laws Introductory Physics Homework 1
Newtons Laws?????????? Introductory Physics Homework 4
