What is the Force Exerted on a Parachutist During Free Fall Deceleration?
The problem involves a parachutist of mass 80 kg who decelerates upon hitting the ground. The context is centered on calculating the force exerted by the ground during this deceleration phase, with specific values given for initial velocity and deceleration distance.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relevance of the provided information, with some questioning whether the weight of the parachutist is the only force to consider. Others suggest calculating the deceleration first using kinematic equations before determining the force exerted by the ground.
There is ongoing exploration of the calculations needed to find the deceleration and the subsequent force. Some participants have provided calculations for deceleration and force, while others are questioning the signs of the forces involved and the implications of deceleration.
Participants are navigating the complexities of deceleration and the forces acting on the parachutist, with some noting the importance of considering gravity in their calculations. There is no explicit consensus on the final interpretation of the forces involved.
Jacobpm64
A parachutist of mass 80 kg approaches the ground at 5 m/s. Suppose that when he hits the ground, he decelerates at a constant rate (while his legs buckle under him) over a distance of 1 m. What is the force the ground exerts on his feet during the deceleration?
[tex]\vec{F} = m \vec{a}[/tex]
I think a lot of this information is extraneous. Isn't the force that the ground exerts on the parachutist going to be opposite his weight?
So, [tex]\vec{F} = mg = (80 * 9.8) = 784[/tex] N
I'm not sure about this because it seems odd that all of that extra information would be given if it is not needed.
Thanks in advance.
I think you're supposed to find the acceleration (decelleration in this case) before you find the force the ground exerts on him.
You're given a velocity, a distance, what equation can you use to determine the decelleration?
So, let's see what I can do.
[tex]x_{0} = 1 m[/tex]
[tex]v_{0} = 5 m/s[/tex]
[tex]x = 0 m[/tex]
[tex]v = 0 m/s[/tex]
[tex]a(x-x_{0})=\frac{1}{2}(v^2 -v_{0}^2)[/tex]
solving for a,
[tex]a = \frac{v^2-v_{0}^2}{2(x-x_{0})}[/tex]
Plugging in the numbers,
[tex]a = \frac{(0)^2 - (5)^2}{2(0-1)}[/tex]
[tex]a = 12.5 m/s^2[/tex]
So, what do I do now, do I still factor in gravity?
ok so decelleration is 12.5m/s^2 now you can use that a in order to find the force he exerts on the ground, and then the force the ground exerts on him.
So,
[tex]F = ma = (80 * 12.5) = 1000 N[/tex]
Final Answer.
How's that look?
yes but the acceleration should be -12.5 since it's deceleration,
so the parachuter exerts -1000N on the ground, and the ground exerts the 1000N on the parachuter.
