Calculating Forces on an Inclined Plane
The discussion revolves around calculating forces acting on a block resting on an inclined plane, specifically addressing static and kinetic friction coefficients, and the forces required to prevent slipping, initiate movement, and maintain constant velocity.
  • Participants explore the relationships between forces acting on the block, including gravitational force components and frictional forces. Questions arise regarding the definitions of constant velocity and the application of Newton's laws in this context.
Participants are actively engaging with the problem, questioning assumptions about force calculations and friction types. Some guidance has been offered regarding the need to consider kinetic friction when discussing motion at constant velocity, and there is an ongoing exploration of the correct application of formulas.
There is some confusion regarding the use of static versus kinetic friction in the calculations, and participants are checking their understanding of the problem setup and the implications of constant velocity on force calculations.
BuBbLeS01
A block weighing 73.7 N rests on a plane inclined at 24.3° to the horizontal. The coefficient of the static and kinetic frictions are 0.28 and 0.11 respectively.
A.) What is the minimum magnitude of the force F, parallel to the plane, that will prevent the block from slipping?
B.) What is the minimum magnitude of F that will start the block moving up the plane?
C.) What is the magnitude of F is required to move the block up the plane at constant velocity?
w = 73.7
theta = 24.3
Mus = 0.28 (Don't know how to make that little symbol lol)
Muk = 0.11
A.) F = w sin theta - Mus*wcos theta = 11.52 N
B.) F = fs + wx
Fmin = Mus*wcos theta + wsin theta = 49.14 N
C.) F = Wx + fk
fk = Muk*N = 7.3889
Wx = fs + F = 11.775 + 11.52
fs = Mus*wcos theta
Part C I don't think is right but I don't know what I am doing wrong?
What does it mean for something to be moving at a constant velocity?
It means that it is not accelerating...Newtons first law I think
No, that has nothing to do with Newton's first law.
http://www.glenbrook.k12.il.us/GBSSCI/PHYS/CLASS/newtlaws/u2l1a.html
Constant velocity means there is no acceleration, meaning from Newton's second law
F = ma
there is no force since there is no acceleration.
Oh ok Newtons second law.
So why isn't it...
F = Wx + fk
What do you mean by F? So, you understand that the forces must sum to zero because there is no acceleration? Also, since velocity is kinetic, you need to use kinetic friction.
-Wx - fk + F = 0
I think you were using static friction. Did you actually get the question wrong, or do you just think you are wrong? It looks like you are right.
the force. Yea I understand that it must = to 0.
so
Wx = fs + F
fk = Muk x W cos theta
Looks fine to me. Watch your signs though.
F = fk + Wx
Actually I am sort of confused now that I look that over once more. Wx = mgsinØ, why do you think it is fs + F? What did you do there?
Nevermind I was looking at the wrong thing I think for Wx, but I did try to do that...
F= (Muk x W cos theta) + (mg sin theta) = 49.14 N
but it says its wrong
I get a different answer, make sure you are in degrees and all that.
F = (0.28 x 73.7 cos 24.3) + (73.7 sin 24.3) = 49.14
its in degrees
Kinetic friction coefficient is .11 :)
omg lol i make the dumbest mistakes!
  • · Replies 68 ·
14K
