Calculating the Force on a Helicopter in Flight
  • Thread starter Thread starter BuBbLeS01
    Force Helicopter
The discussion revolves around calculating the force exerted by air on a helicopter that is lifting a truck while experiencing upward acceleration. The problem involves concepts from dynamics, specifically Newton's laws of motion, and requires understanding of forces acting on the helicopter and the truck system.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the application of Newton's second law and the apparent weight equation. There are discussions about drawing force diagrams and considering the system as a whole, including the helicopter and truck combined mass. Questions arise regarding the forces acting on the helicopter and the nature of the upward force exerted by the air.
Participants are actively engaging in clarifying the forces involved and the relationships between them. Some guidance has been provided regarding the correct interpretation of forces, and there is an ongoing exploration of how to set up equations to find the required force. Multiple interpretations of the problem are being discussed without reaching a final consensus.
There is a mention of potential confusion regarding the mass values used in calculations, as well as the need to consider the tension in the cable holding the truck. Participants are also reflecting on the implications of the large forces involved in the scenario.
BuBbLeS01
A 13000- kg helicopter is lifting a 7100- kg truck with an upward acceleration of 2.1 m/s2. Calculate the force the air exerts on the helicopter blades.
Do I use the apparent weight equation for this?
Wapp = m(g + ay)
No it's Newton's second law.
Draw the force diagram, you can assume that the truck and helicopter are 1 object with the mass of truck+helicopter, since you don't need to know what force the helicopter exerts on the truck.
[tex]\Sigma\vec{F}=ma[/tex]
you know a, the m, and there is 1 force you know that is acting against the helicopter. and then there's the uknown force that the helicopter+truck exert upward in order to attain the acceleration of 2.1 m/s^2 which exerts some force on the air,
and by Newton's third law exerts some force on the helicopter.
so...
F = (20100kg)(2.1m/s^2)
[tex]\Sigma\vec{F}=20100kg * 2.1 \frac{m}{s^2}[/tex]
yes but what's going to be on the left hand side?
the force the air exerts and is there tension force since the plane is carrying the truck by cables?
well yea the force the air exerts but you might want to think of it as the force the helicopter+truck exert upwards against gravity.
and the cables might be necessary if you were determining the force exerted onto the truck by the helicopter.
But there's one force that's pulling the helicopter down. And the force that the helicopter exerts up overcomes this force and gives it an acceleration of 2.1m/s^2
so we have the force of gravity pulling it down...
H - W = 21000 kg x 2.1 m/s^2
H being the force the helicopter+truck exerts?
yes what you want is that H.
but that H is going up, the force the blades exert on the air. You want the force that is opposite of that. Using Newton's 3rd law, the action or reaction of the pair.
You want the force the air exerts on the helicopter+truck... that's an upwards force. We need the forces on the system. Not the forces by the system.
so it would be - H
21000 kg x 2.1 m/s^2 + W = -H
-21000 kg x - 2.1 m/s^2 - W = H
BuBbLeS01 said:
so it would be - H
No. The way you had it the first time was right... H is the upward force the air exerts on the helicopter/truck system.
ok ok I get it now o.o >< forgot how helicopters worked >.>
Yes you had it right just add W to both sides of that equation and you'll get H as a positive #
so if it was by the system it would be - H?
and now I have...
21000 kg x 2.1 m/s^2 + 206010 N = 476721 N
thats big! Is that right or did I miss something?
and now I have...
Well, the answer will be big... but you made a mistake with the mass... it should be 20100 not 21000
hm..it's not 21000kg it's 20100 hehe.
It seems right, it's a huge weight O.O like ~27 tons ~ 54k lb's being lifted up, requires huge force, and to accelerate ...
Okay my mistake...
Now I have to find the tension in the cable holding the truck so would I just do...
-T = m x a + W - H
-T = m x a + W - H
Which body are you taking a freebody diagram of? Deciding that is always the first step.
the helicopter
BuBbLeS01 said:
the helicopter
Oh... ok, then your equation looks right.
