Designing Liquid Delivery System with Servo Motors
  • Thread starter Thread starter hanson
    Liquid System
The discussion revolves around the design of a liquid delivery system intended to handle volumes between twenty ml and a hundred ml. Participants explore the feasibility of using servo motors for control of speed and displacement, as well as alternative pump types suitable for precise liquid delivery.
  • One participant suggests using a servo motor for controlling the liquid delivery system, questioning the possibility of controlling both speed and displacement.
  • Another participant identifies the need for a metering pump as a suitable solution and provides links to suppliers.
  • A follow-up inquiry asks whether metering pumps can handle small volumes like twenty ml to a hundred ml and requests information on their cost range.
  • A participant responds that smaller metering pumps are generally available and suitable for the specified volume, estimating costs to be in the range of a few hundred to a thousand dollars without controls.
  • Another suggestion is made to consider a peristaltic pump as an alternative option.
Participants present multiple competing views on the best approach for the liquid delivery system, with no consensus reached on the most suitable pump type or specific recommendations.
Participants express uncertainty regarding the specific capabilities and costs of metering pumps, as well as the suitability of servo motors for the intended application.
Individuals interested in liquid delivery systems, pump design, or automation using servo motors may find this discussion relevant.
hanson
Hi all.
I am designing a liquid delivery system that should handle liquids of volume like twenty ml to a hundred ml.
Ordinary pumps would not work here.
I am thinking of using a servo motor.
But I would need to control the speed as well as displacement of the servo motor, is it possible?
What else would you suggest?
Thank you, Q_Goest.
I will search over the suppliers for more information.
But do you know if these metering pumps can pump liquid to small amounts like twenty ml to a hundred ml?
And how much would such a pump usually cost? A range will be enough.
Hi hanson,
The metering pumps I've seen are generally very small and would meet your needs. There are much larger ones, but I think the smaller ones are generally used in pharmaceutical industry and other places where a small but precise amount of liquid is desired. I don't use them myself, but I do design various types of pumps. If I had to guess, I'd suspect what you're looking for is on the order of a few hundred to a thousand dollars without controls.
  • · Replies 16 ·
