Help with Hooke's Law Constant and Rubber Bands
The discussion revolves around understanding Hooke's Law, specifically the constant relating length and force, as well as the behavior of rubber bands under stretching forces. Participants are exploring the terminology associated with the constant and the phenomenon of rubber bands shortening under certain conditions.
  • Participants are attempting to identify different names for the constant in Hooke's Law and questioning the reasons behind the observed behavior of rubber bands when stretched. There is also a mention of temperature as a possible factor influencing the behavior of rubber bands.
The discussion is ongoing, with participants providing suggestions and references to external resources. Some guidance has been offered regarding terminology and concepts related to Hooke's Law, but there is no explicit consensus on the explanations for the rubber band's behavior.
Participants are working within the constraints of homework requirements, which may limit the depth of exploration into the concepts discussed. There is an acknowledgment of the need for further research and validation of ideas presented.
allyalt
Help me??
I need to find three different names for the constant between length and force in hooke's law. I also need to find out why, when rubber bands are stretched by force, at a certain force, they actually get shorter. can anyone help?
the only idea i have for why it gets shorter is because of temperature when the band is streched out. but i have no idea if that is accurate.
Let's see, Hooke's law often deals with a spring under force. Look up each of these words as partial terms for the constant in your physics book. Stiffness (check it out first so you can back it up) is a term that might wow your professor.
Get shorter? It's a critical point where the band permanently deforms. See if your book yields the answer.
  • · Replies 35 ·
14K
