How to Determine v0 Using Superposition in a Complex Circuit?
The discussion revolves around determining the output voltage (v0) in a complex circuit using the superposition principle. The original poster seeks clarification on applying this principle to the given circuit diagram.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to understand the superposition principle and its application to the circuit, expressing uncertainty about their calculations and seeking partial guidance. Some participants explain the principle and suggest calculating v0 due to individual sources, while others propose using equivalent sources for simplification.
The discussion is ongoing, with participants exploring different interpretations of the superposition principle and its application. Some guidance has been provided regarding the calculation steps, but there is no explicit consensus on how to proceed with the specific circuit.
The original poster expresses a lack of understanding of superposition and requests assistance with specific parts of the calculation. There is an indication of a circuit diagram being referenced, which is not included in the text.
engineer_dave
Determine v0 for the circuit shown using the superposition principle( circuit diagram is attached to this post)
v0= sum of voltages (is it?)
Voltage due to 3A
Total resistance of the 10ohm resistor parallel to the 8 and 6 ohm resistor in series which is 35/6 ohms.
Either that or I am totally wrong. It would really help if you could just show me one part of the sum, do one of the voltages for me so that I can figure it out and do the same for the rest. I don't really understand superposition that well. Thanks!
The superposition principle says that in a linear circuit, the output voltage or current due to all the voltage/current sources is the same as the sum of the outputs due to each voltage/current source alone, with the other voltage sources replaced by short circuits and the other current sources replaced by open circuits.
So what you have to do is calculate Vo due to the current source alone replacing the voltage source with a short circuit, then calculate Vo due to the voltage source alone replacing the current source by an open circuit, and finally make the sum of the two Vo's you calculated, to obtain the Vo due to both sources.
kool but i still don't get how to apply that to this circuit. Can you show a bit of the solution..maybe the first part. Cheers!
Are you having difficulties calculating Vo due to the current source alone? Maybe it would be easier if you replaced the current source with it's equivalent voltage source.
