Thought Experiment - Measuring speed of light
The discussion revolves around the thought experiment of measuring the speed of light from the perspective of a photon, exploring concepts of relativity, reference frames, and the implications of traveling at light speed. Participants engage with theoretical implications and the nature of measurement in relativistic contexts.
  • Some participants propose that as one approaches the speed of light, the universe appears to contract, yet the speed of light remains constant as measured by distance over time.
  • Others argue that from a photon's perspective, the entire universe would appear as a single point, raising questions about how a photon could measure anything given its lack of a reference frame.
  • A later reply questions the validity of discussing a photon's reference frame, noting that the Lorentz transformation yields nonsensical results when attempting to apply it at light speed.
  • Some participants suggest that if one considers time dilation, one must also consider length contraction, as both are integral to the relativistic framework.
  • There is a contention regarding the interpretation of what happens to distances and times as one approaches the speed of light, with some asserting that distances along the direction of motion become zero.
  • One participant introduces the idea that photons do not exist as free entities but rather as quanta of a field, which complicates their measurement and existence in a traditional sense.
Participants express multiple competing views regarding the nature of a photon's perspective and the implications of relativity. There is no consensus on how to interpret the measurements or the existence of a reference frame for photons.
Participants highlight limitations in applying traditional concepts of reference frames and measurements to photons, noting unresolved mathematical implications and the challenges of discussing relativistic effects at light speed.
Xori
Here's my thinking: The faster you go relative to the universe, the more the universe appears to contract. However, c remains constant as measured by distance/time.
Now, what about to a photon? To a photon, the entire universe would appear as a single point, correct? To this same photon, c would remain constant as observed by the photon. But how can the photon know this? It's entire distance is infinitely small, and therefore it can't perform the distance/time measurement.
Is my logic wrong?
Is my logic wrong?
A photon does not have its own reference frame in relativity--the whole concept of each observer having their own frame is based on the idea of their having a network of measuring-rods and sychronized clocks moving along with them, but this doesn't make sense in the case of a photon. See this thread for an older discussion about this.
Perhaps it would see a point, but even if a photon had a point of view, it would be impossible to know what it is like. If the theory of relativity is correct, then a single moment from the reference frame of a photon is equal to an infinite amount of time in the normal reference frame.
What do you mean "if the theory of relativity is correct"? The Lorentz transformation gives nonsensical answers if you try to plug in v=c, so the phrase "the reference frame of a photon" simply has no well-defined meaning according to relativity.
Replace v=c with v->c, and generally replace instances of "to be" with "tends to". It's sloppy, but occasionally it's worth the shorthand. However, in this case, I agree with you -- it's important to realize that there is no frame in SR that corresponds to the rest frame of a photon.
Even talking about limits, "then a single moment from the reference frame of a photon is equal to an infinite amount of time in the normal reference frame" isn't really correct. In the limit as a ship's velocity approaches c, we will see the ticks of its clocks stretched out arbitrarily long in our frame, but it will also see the ticks of our clocks stretched out arbitrarily long in its own frame. However, it will also see clocks that are synchronized in our frame and which lie along the direction of motion as being very out-of-sync and close together--if two clocks at opposite ends of the galaxy are synchronized and 20,000 light years apart in our frame, then in the frame of someone moving at very close to the speed of light along the line between them, both clocks would be ticking very slowly, but the clock they're moving towards will show a date close to 20,000 years ahead of the clock they're moving away from, and the distance between the clocks would be very small so it would take a very small time to pass from the first clock to the second (and in the limit as v approaches c, 'very small' approaches zero, while these clocks would approach being completely frozen at their respective dates).
in the photon's ref frame, it takes zero time to travel across any distance. so things still make sense?
In a photon's reference frame (to the extent that we can speak of such a thing), all distances along the direction of motion are zero. If you're going to try to apply time dilation to this situation, you'd better also apply length contraction, too. :wink:
What ?? This does not make sense unless you have a universal frame of reference.
I'm not even going to read the rest. Go study SR.
I wans't implying a universal frame of reference. I meant as you go faster relative to everything else, it contracts. If you go the speed of light (as a photon does), everything else in the universe appears to have a length of 0.
So how can a photon possibly measure the speed of light if everything is infinitely close?
Hi Xori,
I see what you are trying to say. Your question has been well answered above.
Anyhow, I don't think photons exist as free entities. They exist when they are created and when they are absorbed. In between they are quanta of a field that obeys Maxwells equations, and beyond that we can't say much about them.
As already said, the only dimension that is contracted is the direction of the mouvement.
If an object closes to the speed of light (or if we assume that the light has a frame of reference), the hole universe would seem to be just plane perpendicular to the mouvement, not a point.
That's my 2 cents :)
Correct me if I am wrong.
http://ghazi.bousselmi.googlepages.com/présentation2
  • · Replies 55 ·
  • · Replies 25 ·
  • · Replies 26 ·
  • · Replies 42 ·
  • · Replies 25 ·
  • · Replies 51 ·
