Velocity/Accelration/Displacment all in one question.
  • Thread starter Thread starter veloix
The discussion revolves around a kinematics problem involving a moped's motion, as represented by a velocity versus time graph. Participants are tasked with sketching related graphs for position versus time and acceleration versus time, while also calculating specific values at given times.
  • Mixed
  • Participants explore the relationship between velocity, position, and acceleration, discussing how to derive position from the area under the velocity graph. Some question the need for integration versus calculating areas of geometric shapes.
There is an ongoing exploration of the equations for velocity across different segments of time. Participants are sharing calculations and questioning assumptions about slopes and intercepts. Some guidance has been provided regarding the integration of velocity to find position, but no consensus has been reached on all aspects of the problem.
Participants are working under constraints of homework rules that require sketching graphs by hand and providing numerical values for specific points. There is also a mention of potential confusion regarding the correct interpretation of graph segments and their respective areas.
veloix
A student drives a moped along a straight road as described by the velocity versus time graph in Figure P2.14. The divisions along the horizontal axis represent 1.5 s and the divisions along the vertical axis represent 3.5 m/s.
Sketch this graph in the middle of a sheet of graph paper. (Do this on paper. Your instructor may ask you to turn in your work.)
Figure P2.14
<img src=http://a425.ac-images.myspacecdn.com/images01/103/l_3fca2200153cb8eb21ea540316125000.gif>
(a) Directly above your graph, sketch a graph of the position versus time, aligning the time coordinates of the two graphs. (Do this on paper. Your instructor may ask you to turn in your work.)
(b) Sketch a graph of the acceleration versus time directly below the vx-t graph, again aligning the time coordinates. (Do this on paper. Your instructor may ask you to turn in your work.)
On each graph, show the numerical values of x and ax for all points of inflection.
(c) What is the acceleration at t = 9.0 s?
m/s2
(d) Find the position (relative to the starting point) at t = 9.0 s.
m
(e) What is the moped's final position at t = 13.5 s?
m
all of the kinematics and equations dealing with velocity,time,positon,accerlation
will help out
let see i figured the part looking for accelration out by taking the a tanget of the line near 9s using equation for slope form. vf-vi/tf-ti= 0-14m/s/12s-9s=-4.67m/s^2
now the rest I am totally lost I've tried to intergrate the function of the graph but I am not sure how to come up with the equation of the function. can anyone help me out?
heres the graph
The acceleration is just the slope of the lines...
The change in position is the area under the v-t graph...
ok the area under the curve, now this where I am getting stuck. do i use intergration?
You don't have to... suppose I'm looking at the first segment of the curve (the positive slope part)... so 0 up to some time t... what is the area under the graph ?
lets see the area under the first part. looks like two triangles. so area of the first triangle is bXhX1/2 =1/2 4.5X(14)=31.5 and the 2nd 1/2X4.5X(14)=31.5 so 31.5+31.5= 63
veloix said:
lets see the area under the first part. looks like two triangles. so area of the first triangle is bX1/2h = 4.5X1/2(14)=31.5 and the 2nd 4.5X1/2(14)=31.5 so 31.5+31.5= 63
Why are you getting 2 triangles? I just see one...
suppose you aren't going all the way to t = 4.5. you're calculating the area from t = 0... to some t = tf... what is the area of the triangle?
Actually maybe it is better to take the integral... so for the first segment... what is the equation for v(t) ? ie: for t = 0 to t = 4.5...
equation for v(t)= absx
what is abs?
You want an equation for v(t) in terms of time...
v(t)=│t│
t=0
v(t)=│0│=0
t=4.5
v(t)=│4.5│=4.5
veloix said:
sry ment absoultevalue of t.
Hmmm... how do you get that? I see the slope as 14/4.5 = 3.111
veloix said:
v(t)=│t│
t=0
v(t)=│0│=0
t=4.5
v(t)=│4.5│=4.5
Isn't v = 14 at t = 4.5?
You don't need to use absolute value... since time is positive anyway.
yea v= 14 at t= 4.5 , my mistake on that.
so if i were to intergrate that. it be ∫v(t) dt
veloix said:
so if i were to intergrate that. it be ∫v(t) dx
dt not dx.
But that equation for v(t) only holds for t = 0 to t = 4.5... What is the equation of each segment of v(t) ?
When you get that, then you can get the integrals...
t=0 to t= 4.5
v(t)=t
t=4.5 to t=9
v(t)=14
t=9 to t= 15
v(t)=(-t-12)
veloix said:
t=0 to t= 4.5
v(t)=t
But the slope of the line is 14/4.5 = 3.11 so this can't be right.
t=4.5 to t=9
v(t)=14
Yes, good.
t=9 to t= 15
v(t)=(-t-12)
you calculated the slope of this part in your original post... it's not -1
ok so first one must be v(t)=3.11t
and the last is v(t)=(-4.67t-12)
yes.
The slope is right, but the y-intercept is wrong.
hmm well i figured it was a reflection of the f(t) and it shifted to the right to 12. but i guess i didnt do it right. should i extend the line to the y-axis to get the intercept?
ok shoot now i c. it should be v(t)=(-4.67t-52.5)
The y-intersepct should be positive... the line segment when extended will hit the y-axis at a positive value.
you know that v(t) =-4.67t + b, just plug in the t value and v value at a point... then solve for b.
ok thanks
(v)t=(-4.67t+56.04)
veloix said:
(v)t=(-4.67t+56.04)
I'm getting v(t) = -4.67t + 49.03, using v(10.5) = 0
i c yes you are right i was wrong again. v(t)=-4.67+49.03 using v(10.5)=0
Anyway, from here you can calculate the position using:
[tex]x(t)= x_0 + \int_0^{t}v(t)dt[/tex]
I think perhaps x_0 = 0 ?
so:
[tex]x(t)= \int_0^{t}v(t)dt[/tex]
you'll have 3 sections: where t = 0 to t = 4.5... from t=4.5 to t=7.5, and from t=7.5 to 13.5
ah... you had 9, instead of 7.5... maybe that was where the mistake was coming from.
ok I am going try to work this out
cool. when you take the integral from 0 to some value between 4.5 and 7.5... eg 6... you split the integral into two parts... the integral from 0 to 4.5, and the integral from 4.5 to 6... ie divide them into the segments... hope that makes sense.
wow i got the right answer. you were a very big help on this one i don't know how i can thank you but there is one more problem i have. let me show this graph for a sec.
(a) Determine the particle's speed at t = 6.0 s.
What is the speed at t = 12.0 s?
(b) Find the distance traveled in the first 12.0 s.
m
is this going be another one like the prevoius one? when the lines are going down like that one the graph, i not sure what the velocity is doing i know when velocity is changing accelration will be changing. and when the velocity is is not changeing accelration is 0.
9K
  • · Replies 30 ·
  • · Replies 21 ·
