How Do You Linearize the Equation d=vit + 1/2at^2?
The discussion focuses on linearizing the equation d = vit + 1/2at² by transforming it into different variable relationships: d/t² vs 1/t, t/d vs t²/d, and 1/d vs 1/t. The key approach involves rearranging the equation into the linear form y = mx + b. Specifically, for the first transformation, the equation becomes d/t² = vi/t + 1/2a, where y is defined as d/t² and x as 1/t, resulting in a linear graph with a slope of vi. The participant expresses confusion about manipulating the original equation but ultimately identifies the correct substitutions and transformations.
  • Understanding of kinematic equations, specifically d = vit + 1/2at²
  • Knowledge of linear equations in the form y = mx + b
  • Familiarity with graphing techniques for linear and non-linear relationships
  • Basic algebraic manipulation skills, including substitution and division
  • Study the process of linearizing quadratic equations in physics
  • Learn about graphing techniques for analyzing linear vs non-linear relationships
  • Explore the use of the quadratic formula in solving for variables in kinematic equations
  • Practice transforming other kinematic equations into linear forms for graphing
Students studying physics, particularly those focusing on kinematics, as well as educators looking for methods to teach linearization of equations effectively.
daewoo
basically I am suppose to linearize d=vit + 1/2at^2 into d/t^2 vs 1/t, t/d vs t^2/d and 1/d vs 1/t
and its asking which graphs would be linear and non-linear.
d=vit + 1/2at^2
all i know is that in order to linearize this i need to make it into the format y=mx+b from there i can see which variables alternate and which remain constant.
now I am confused on how I am suppose to get d/t^2 vs 1/t for the first one so i started to solve for t but i ended up needing to use the quadratic equation since its ax^2 + bx + c=0 but that really didnt help me since i coudlnt isolate "d" again. So basically I am kinda lost on how to manipulate this formula.
For the first part, I'd let y = d/t^2, let x = 1/t. Can you get the d and t equation into an equation with y and x... substitute appropriately and manipulate the formulas.
If you divide the equation by t^2 you get
[tex]\frac{d}{t^2} = \frac{v_i}{t} + \frac{1}{2}a[/tex]
If you wanted that against 1/t, basically make x a substitution of 1/t, you would have a graph that looked pretty linear with a slope of vi.
Do you see how it works?
  • · Replies 20 ·
