What Is the Resultant Force When Two People Pull on Ropes Attached to an Object?
The resultant force when two people pull on ropes attached to a heavy object can be calculated based on the direction of the forces. When both individuals pull in the same direction, the total resultant force is 2000N. If they pull in opposite directions, the resultant force is 0N. For forces applied at right angles to each other, the resultant force is determined using vector geometry, specifically the Pythagorean theorem, resulting in a force of approximately 1414.21N.
  • Understanding of vector addition and resultant forces
  • Knowledge of the Pythagorean theorem
  • Familiarity with Newton's laws of motion
  • Basic principles of force resolution into components
  • Study vector addition in physics
  • Learn about force resolution and components
  • Explore applications of the Pythagorean theorem in physics
  • Review Newton's laws of motion for practical examples
Physics students, educators, and anyone interested in understanding the principles of force and motion in mechanics.
motoxtremechick
two ropes are attatched to a heavy object. the ropes are given to two strong people with instructions for each to pull with 1000N of force. what is the total resultant force if the two women pull..
in the same direction_________F=2000N
in opposite direction__________F=0N
at right angles to each other?_______F=?
did i do the first two right?
what would i do for the right angles?
Yes, first two parts look right. Use vector geometry for the third part... ie pythagorean theorem.
The last one I assume that one is looking down from the top and the ropes are making an angle of ninety degrees with each other. Let's say the ropes are pointing from the heavy object "upwards" (on paper). If one resolve the two 1000 N forces into x- and y-components the x-components will cancel each other out and the y-components will add up.
  • · Replies 38 ·
  • · Replies 25 ·
