Finite Dimensionality of Linear Map on V
  • Thread starter Thread starter *melinda*
    Linear
The discussion centers on proving that if a linear map T on a vector space V has both a finite-dimensional null space and a finite-dimensional range, then V itself must be finite-dimensional. Participants clarify that while T(v) being in the range(T) does not imply v is not in null(T), it is essential to establish bases for both null(T) and range(T). The conversation highlights the misconception that V can be expressed as a direct sum of these spaces, emphasizing the need for a rigorous proof that incorporates the finite dimensions of both null and range.
  • Understanding of linear maps and their properties
  • Familiarity with vector spaces and subspaces
  • Knowledge of finite-dimensionality concepts in linear algebra
  • Ability to construct and analyze bases for vector spaces
  • Study the concept of direct sums in vector spaces
  • Learn about the Rank-Nullity Theorem in linear algebra
  • Explore examples of linear maps and their null spaces and ranges
  • Investigate proofs related to finite-dimensional vector spaces
Students of linear algebra, mathematicians, and educators seeking to deepen their understanding of finite-dimensional vector spaces and linear mappings.
*melinda*
Prove that if there exists a linear map on V whose null space and range are both finite dimensional, then V is finite dimensional.
The attempt at a solution
I *think* the following is true: For all v in V, T(v) is in range(T), otherwise T(v) = 0 which implies v is in null (T).
Other than that, I know I can write a basis {v_1, ..., v_n} for null(T) and a basis {T(u_1), ..., T(u_m)} for range(T), where range(T) = {T(u) : u is in V}. But since this is a linear map {u_1, ..., u_m} should also be a basis for some U such that U is a subspace of V.
Does anyone know if these assumptions are heading in the right direction?
No, that's not true. T(v)= 0 even when T(v) is in range(T) because 0 is in range(T) (range(T) is a subspace). For a simple example, let V= R2, T<x,y>= <x-y,x-y>. null(T) consists of all vectors of the form <x,x>. Range(T) is exactly null(T).
You seem to be assuming that V is the direct sum of range(T) and null(T) and that's not true.
ok, but can I at least write a basis for null(T) and range(T)? I can't see how to prove this without defining something, because I know I can't prove this by only referring to the finite dimensions of null and range.
  • · Replies 24 ·
