What is the speed of the crossbow arrow when it is released?
The problem involves calculating the speed of a crossbow arrow upon release, utilizing principles from physics such as conservation of energy and work-energy relationships. The scenario includes specific measurements of force, displacement, and the mass of the arrow.
  • Participants discuss the relationship between force, displacement, and energy, questioning how to apply these concepts to find the arrow's speed. Some explore the calculation of the spring constant and the implications of varying force with displacement.
Several participants have provided insights into the energy calculations and the relationships between work done and kinetic energy. There is an ongoing exploration of the correct application of formulas and unit conversions, with some expressing confusion about their calculations.
Participants note the importance of accurate unit conversions and the potential for small errors to significantly affect results. There is also mention of homework guidelines discouraging multi-posting, which has led to some merging of threads.
Ryo124
[SOLVED] Conservation of Energy
I know, this problem is making me feel dumb but I can't figure it out:
A crossbow takes 50.0 pounds of force to draw the arrow back by 12.5 inches, and the weight of the arrow is 2 ounces. What is the speed of the arrow when it is released?
(1 lb = 4.448 N; 1 in = 2.54 cm; 1 oz = 28.35 grams)Could someone show me how to solve this?? Thanks to whoever helps.
*It is not momentum, but conservation of energy, sorry.
This is a homework problem in Introductory Physics. And please do not do multi-posting.
With the force and displacement, one can determine a spring constant. The force usually decreases with displacement, unless the bow is specially designed for constant force.
Knowing the force one can determine the acceleration of the mass (arrow), and from the acceleration the velocity.
The other part as mgb_phys pointed out is that the energy stored in the bow (spring) must equal the kinetic energy of the mass when the bow string reaches its rest (zero) position.
And the work released = F*d, where F is the force and d is the displacement. But the question then becomes, is F a function of displacement (x), where 0 < x < d.
How much energy does the crossbow have before the arrow is released? ie: how much work has been done on the crossbow?
Work is force * distance and kinetic energy is 1/2mv^2.
So assuming all the energy goes into the arrow it's pretty simple
Why have you posted this exact question 4 times on the forums?
Threads merged--DO NOT multi-post!
Still not getting it for some reason...
I found the spring constant (k) to be -700.472
I found the acceleration (a) to be 392.24 m/s/s
I found the total work (W) on the system before the arrow is shot to be 70.612 J
W = Fd = 50(4.448)(.3175m) = 70.612 J
I am not sure what to do from here, the only thing that I do know is:
(1/2)mv^2 + mgh + (1/2)kx^2 = (1/2)mv^2 + mgh + (1/2)kx^2
Do I need to even use this equation? Setting Work equal to (1/2)mv^2 does not give me the correct answer. What am I not doing correctly? Is there energy that I am missing.
I know this is a simple problem and I have NO IDEA why it is causing me so much trouble. Will someone please help so more?
(1/2)kx^2 = 32.538J
set (1/2)mv^2 = 32.538
m = 0.0567kg
v= 33.88m/s ? I think this is the way to do it.
If 50lb, is the average force in pulling the arrow back then...
70.612J = (1/2)mv^2
v = 49.9m/s. Is that what you got?
EDIT: oops... should be 35.29m/s as ryo calculated. I used 12inches, instead of 12.5inches.
Ouch
Instead of using .0567 m, I was using .567 m. Oh well, I stressed over such a small mistake. So, I got
(1/2)700.472(.3175)^2 = (1/2)(.0567)v^2
v = 35.29 m/s !
Thanks for the input guys, it all made sense. I just incorrectly converted g into kilograms. Maybe I was thinking in terms of m to cm and dividing by 100 instead of 1000. Thanks though guys!
14K
