Find speed and acceleration of truck
The problem involves a truck covering a distance of 40 meters in 8.50 seconds while decelerating to a final speed of 2.80 m/s. Participants are tasked with finding the original speed and acceleration of the truck.
  • Mixed
  • Participants discuss the appropriate equations to use for calculating the original speed and acceleration, with some questioning the validity of using average speed formulas in this context. There is also a discussion about the relationship between initial speed and acceleration.
Some participants have offered guidance on which equations might be relevant, while others are exploring different interpretations of the problem. There is an acknowledgment that certain formulas may not be directly applicable without additional information.
Participants are navigating the constraints of using kinematic equations under non-constant acceleration conditions, and there are indications of confusion regarding the definitions of initial and final speeds.
012435
1. Homework Statement
a truck covers 40m in 8.50s while slowing down to a final speed of 2.80m/s
2. Homework Equations
find original speed
find it's acceleration
3. The Attempt at a Solution
for original speed i think it is 40m/8.50s= 4.7m/s
now for acceleration i am not sure which kinematic equation to use. i think it's Vf=Vi+at am i on the right track or no
That's not right... for original speed.
d = vt only applies for constant speed situations...
you need a different equation to find the original speed.
so is the original speed then the same as the initial speed
yes, what equation do you know that relates velocity, initial velocity, and time?
well for acceleration you would use a= (Vf-Vi)/t
for initial speed would you use a=2(x-V1t)/t^2
Yes, but the acceleration formula here requires initial speed... the initial speed formula requires acceleration... so neither of these formulas let you get started...
you can calculate original speed immediately. which formula let's you get it?
can u set these two equations equal to each other, cancel acceleration and solve for Vi or am I making it more complicated
d = (v1+v2)/2 * t
You can use this to get the original speed.
i get it ..thank u
