Finding Tennis Racquet String Tension
  • Context: High School
  • Thread starter Thread starter anirudhreddy
    String Tennis Tension
The discussion revolves around methods for determining the tension of tennis racquet strings in a lab setting. Participants explore various approaches, including both destructive and non-destructive techniques, while considering practical applications and theoretical implications.
  • One participant asks for a lab-doable method to find string tension, specifying a preference for non-destructive techniques.
  • Another participant suggests that measuring string flex under applied force and curve fitting the results may be necessary, noting potential changes over time due to string wear.
  • A different viewpoint proposes using mechanical properties of the racquet's head material to measure deformation with and without strings, although the participant expresses uncertainty about this approach.
  • One suggestion involves plucking the string to measure the frequency of vibration and using physics to calculate tension, while another proposes clamping the string and measuring the force needed for slight displacement.
  • A participant recommends dropping a tennis ball on the strings and measuring the bounce height, comparing it to a racquet with known tension.
Participants present multiple competing views on how to measure string tension, with no consensus reached on a specific method. The discussion remains unresolved regarding the best approach.
Some methods proposed depend on the mechanical properties of materials, while others rely on empirical measurements. There is uncertainty regarding the effects of string wear and the initial tension after stringing.
anirudhreddy
Could you guys please tell me a very lab-doable method for finding the tension of the strings of a tennis racquet?
thx
Does it have to be non-destructive?
Yup. i play tennis with that racquet
I don't think it can be done via an algorithm. You'd have to actually restring a racquet with various tensions and then measure how much the strings flex when a force is applied to the center of the racquet and curve fit the results. Even this may change over time due to friction and wear of the strings.
I'm also not sure if the strings "relax" after the initial stringing of a racquet. Players find a stringing tension they like and stick with that. Current racquets, the new polyester strings, and stringing machines are pretty accurate compared to older times when you could see players bouncing the edge of a racket against the strings of another racquet to choose which one to play with.
If you know the mechanical properties of the 'head', be it wood, fibreglas, carbon fibre, or whatever... maybe you can do distortional measurements with and without the strings to see how much deformation they cause?
From the other end, if you know the physical properties of the strings themselves, you can perhaps do deformation measurements of the 'web?' under various load conditions.
I'm just pulling stuff out of my ass here, though, because I really don't know anything about the subject.
thx
1. Pluck the string, and measure the frequency of vibration. Then use physics.
2. Clamp the string. Measure the force required to pull it the slightest amount.
Compare.
Drop a tennis ball on the strings. Measure how high it goes. Of course, you would have to compare it to the bounce on a racket with known tension.
  • · Replies 16 ·
  • · Replies 22 ·
