Instant Non-sequencial Calculation of colisions b/w objects
  • Thread starter Thread starter Luke_M
    Calculation
This discussion focuses on the simultaneous collision of multiple objects in a physics simulation, specifically addressing the scenario where balls A, B, C, D are moving at a velocity of 1 m/s to the right and collide with stationary ball E while ball F, moving down at 1 m/s, collides with ball A. The participants emphasize the importance of using a two-set value system for managing current and next velocities to accurately simulate non-sequential collisions in a game physics engine. The suggestion to avoid using threads for this purpose is highlighted due to their unpredictable timing, which can lead to inaccuracies in the simulation.
  • Understanding of basic physics principles related to collisions
  • Familiarity with programming concepts, particularly loops and data structures
  • Knowledge of game physics engines and simulation techniques
  • Experience with multithreading and its implications in programming
  • Research "Physics-based collision detection algorithms" for accurate simulations
  • Explore "Game physics engines" like Box2D or Unity's physics system
  • Learn about "Data structures for game state management" to handle current and next values
  • Investigate "Multithreading vs. single-threaded game loops" for performance optimization
This discussion is beneficial for game developers, physics simulation programmers, and anyone interested in creating accurate and efficient collision detection systems in their projects.
Luke_M
Balls A,B,C,D are traveling at V=1 to the right next to each other like a train they hit ball E whom is stationary. At the exact instant ball F is traveling down and hits A, F is traveling at V=1 but down
Here is a diagram this is birds eye view:
*=collision
both collisions have happened at the same time
V
F
-------->ABCD*E
A: Vx=1 m=10
B: Vx=1 m=10
C: Vx=1 m=20
D: Vx=1 m=10
E: Vx=0 m=60
F: Vy=1 m=10
will object E receive any Vy ?
why not ?
what are the new V's ?
I need to know how to work this out as I am making a physics model in my game.
If you are a programmer maybe you can also answer this question:
In the real world collisions can happen all at once like in my above example. How can I do this in code ? I can only do them sequentially with for loops. is this normal practice in constructing a physics engine. Because if I do the collision between F and A after the other collisions A's new V will incorrectly not be included in the calculation.
Thanks in advance.
Technology news on Phys.org
Luke,
The physics part I cannot easily help you with. As for the programming part, when you want multiple things to happen in parallel you use threads. A thread is a lightweight process. Each thread gets a timeslot much like a process does in a multiprocessing operating system. This is the closest you will get to having them run non-sequentially. I hope this helps.
Ryan
I would not use threads for this because their time slices are unpredictable: some threads will sleep longer than others, causing your model to also be unpredictable. Instead, I would maintain two sets of values for each entity in your model: current values and next values. At each iteration of the loop, use the current values as input in the calculation of the next values. At the end of the loop, set the current values to the 'next' values you just calculated for use in the next iteration.
  • · Replies 30 ·
