Erupting Volcano Kinematics in 2D problem
The discussion focuses on calculating the initial speed and time of flight of a boulder projected from a 2.5 km tall volcano at a 40-degree angle, landing 6.0 km away. The participant is struggling with the kinematic equations, particularly in determining the time of flight and the initial velocity components. The horizontal distance formula S = V(i) * t is applied, but the participant is unsure how to derive time from the given parameters. The elevation of the landing point is also a critical factor, as it is 2.5 km below the launch point.
  • Understanding of kinematic equations in projectile motion
  • Knowledge of trigonometric functions for angle calculations
  • Familiarity with coordinate systems in physics
  • Basic principles of motion under gravity
  • Study the derivation of projectile motion equations, focusing on initial velocity and time of flight
  • Learn how to apply trigonometric identities to resolve velocity components
  • Explore the concept of vertical and horizontal motion in projectile problems
  • Review examples of similar projectile motion problems to reinforce understanding
Students in physics, particularly those preparing for exams involving projectile motion, as well as educators seeking to clarify kinematic concepts in real-world applications.
DeltaDeltaDelta
Ok, I've been working on this for awhile and I can't seem to understand how to work it out. ANY insight would be greatly appreciated!
The problem: An erupting volcano (2.5 km tall) projects a boulder from a vent at an angle of 40 degrees to the horizontal direction. The rock lands 6.0 km away. Introduce an appropriate coordinate system, tailor kinematic equations to the given information and determine the initial speed of the rock and time of flight.
So basically, I'm having a huge mental block trying to figure out the initial velocity. So far I've come up with some answers, but I believe they're incorrect. I took my equation for distance in the horizontal direction S= V(i) * t. and solved for time. You know that the distance in the x direction is 6000 meters. So the Initial velocity in the x direction will be X distance/time. But I didn't know how to find the time, and I was only solving for the x component of initial velocity anyway! Like I said, any thoughts would be helpful because I've been stuck on this for a LONG time, and I've got a midterm coming up where I have to determine the initial velocity of a bullet and accurately fire a metal ball at some predetermined angle directly into the center of a cart some distance away.
The solution will depend on the elevation of the ground where the boulder lands. If the volcano is 2.5 km tall, does this imply the boulder lands at an elevation 2.5 km below its initial lauch point.
The initial velocity is to be determined from the equations of motion, and the fact that one has a horizontal distance of 6 km.
See - http://hyperphysics.phy-astr.gsu.edu/hbase/traj.html#tra9
  • · Replies 21 ·
  • · Replies 32 ·
