Proving the Existence of a Map: f, h, and g
  • Thread starter Thread starter P3X-018
    Existence Map
The discussion revolves around proving the existence of a map \( g: \mathcal{Y} \rightarrow \mathcal{Z} \) given two maps \( f \) and \( h \) with specific properties related to \( \sigma \)-algebras. The original poster is uncertain about how to approach the problem and seeks clarification on the implications of the assumptions provided.
  • Participants discuss the implications of \( f \) being surjective and whether it could also be injective. There is a focus on the necessity of finding a way to associate points in \( Y \) to points in \( Z \) through the composition of maps. Questions arise about the conditions under which such a map \( g \) can be established and the relevance of the assumption that \( \mathbb{G} \) separates points in \( Z \).
The discussion is ongoing, with participants exploring various interpretations of the problem. Some guidance has been offered regarding the relationship between the maps and the properties of \( \sigma \)-algebras, but no consensus has been reached on a definitive approach or solution.
Participants note the importance of the assumptions regarding the measurability of \( h \) and the separation of points in \( \mathbb{G} \), which may influence the existence of the map \( g \). There is also mention of the need to demonstrate the measurability of \( g \) in relation to the properties of \( f \).
P3X-018
I have 2 maps f and h such
[tex]f :\, (\mathcal{X}, \mathbb{E}) \rightarrow (\mathcal{Y}, \mathbb{K})[/tex]
[tex]h :\, (\mathcal{X}, \mathbb{E}) \rightarrow (\mathcal{Z}, \mathbb{G})[/tex]
where [itex]\mathbb{K}[/itex] and [itex]\mathbb{G}[/itex] are [itex]\sigma[/itex]-algebras on the spaces Y and Z respectively, and [itex]\mathbb{E} = \sigma(f)[/itex] is the [itex]\sigma[/itex]-algebra generated by the map f.
f is assumed to be surjective and [itex]\mathbb{G}[/itex] is assumed to separate points in Z. That is for any 2 different point a and b in Z we can find a set [itex]A\in \mathbb{G}[/itex] such that [itex]a\in A[/itex] and [itex]b \notin A[/itex].
The problem is that, assuming h is [itex]\mathbb{E}[/itex]-[itex]\mathbb{G}[/itex] measurable, to show that there is a map [itex]g:\, \mathcal{Y} \rightarrow \mathcal{Z}[/itex] such that [itex]h = g\circ f[/itex].
I don't even know how to attack this problem. What is even meant by showing that there IS such a map? A hint could be helpful.
Can you go from (Y,K) to (X,E)? If you can, then you know how to go from (X,E) to (Z,G).
So if I could go from (Y,K) to (X,E) that is if there was a inverse map of f, that would be enough to conclude that THERE IS a map g?
But f would have to be bijective inorder to go from Y -> X.
Can f be injective under the given assumption? Because it's already surjective, so if it were injective we would be done.
You do not assume injectivity.
Clearly the hypotheses have been given for a reason. So start to see what you can deduce from them. Let's see what you need to do. You need, given a point y in Y to find a way to associate it to a point g(z) in Z. And we need to do it in such a way that gf(x)=h(x). Wow, what do you know, from just writing that down I've essentially solved the question for you...
I didn't mean that I assumed f to be injective, only that wether it should (or could) be shown that f is injective, and if so would that solve the problem, since we could go from Y to Z by h(f^(-1)(y)).
Hmm this sounds too 'simple'...
So basically the argument is, that since f is surjective then for every y in Y there is a x in X, such that y = f(x), and since z = h(x), z is the element in Z that is mapped into by y = f(x), with g(f(x)) = h(x), that is z is mapped by z = g(y).
EDIT:
Another question is to show that g is K-G measurable.
Now if I could look at the map from Y -> X that is [itex]f^{-1}[/itex], then I could use the theorem that says that g is K-G measurable if and only if [itex]f^{-1}[/itex] is K-E measurable, assuming that h is E-G measurable.
I'm pretty certain of that I need to use this theorem, somehow, to show the measurability of g, since obviously I can't investigate wether [itex]g^{-1}(A) \in \mathbb{K},\,\, \forall A\in\mathbb{G}[/itex].
What was the other assumption in the original question that you've not used? The one abotu G separating points. PErhaps that is useful.
