Pure Electron Diffraction Experiments
The discussion revolves around pure electron diffraction experiments, particularly focusing on the double slit experiment and its variations. Participants explore the historical significance of these experiments, the implications of using lower energy electrons, and the potential for using more than two slits in diffraction studies. The conversation touches on both pedagogical aspects and technical challenges associated with these experiments.
  • Experimental/applied
  • One participant notes the significance of the double slit experiment with electrons, comparing it to the Young experiment with light, and questions whether other experiments with lower energy electrons and larger slits have been conducted since 1962.
  • Another participant introduces the concept of using more than two slits for electron diffraction, mentioning the Low Energy Electron Diffraction (LEED) technique as a common method for determining crystal lattice orientation.
  • A different participant emphasizes the pedagogical value of the two-slit experiment for educational purposes, expressing interest in the challenges of conducting low energy double slit experiments with electrons.
  • One participant expresses curiosity about the technical difficulties associated with using low energy electron beams, particularly below thermal levels, and seeks information on past experiments in this area.
  • There is a mention of an active thread discussing diffraction of macroscopic objects, which some participants find relevant to their inquiry about macroscopic slits in electron diffraction.
Participants express varying interests in the historical and pedagogical aspects of electron diffraction experiments, but there is no consensus on the existence of specific experiments with lower energy electrons or the technical implications involved. The discussion remains open-ended with multiple viewpoints presented.
Participants acknowledge the technical challenges of conducting low energy electron diffraction experiments, particularly regarding the size of slits and the energy levels of the electron beams used. There are also references to the limitations of existing knowledge and the desire for broader exploration beyond easily accessible parameters.
lalbatros
Hello,
I just read about the the ten most beautiful experiments of all times.
The top winner was the double slit diffraction by electrons experience carried out by Claus Jönsson .
This electron diffraction experiment, I think, has been chosen as remarquable because it stages the wave-like behaviour of electrons in an experiment that is very close to the Young experiment on normal light. The Young experiment is rather popular probably because it is rather easy to perform.
But there is still a difference with the "normal Young experiment": the size of the double-slit.
The double slits used with 50keV electron was in the micron-size, while nomal Young experiments are carried out in the millimeter range of dimensions.
Therefore I have this question:
Since 1962, have there been other double slit experiments been carried out with electrons of much lower energies and therefore much larger slits?
By the way, I would eventually like to read about the technical implications such lower energies may have.
thanks
thanks
What about electron diffraction using more than just 2 slits? What about electron diffraction/interference equivalent to diffraction grating? The Low Energy Electron Diffraction (LEED) technique is something that is used very often in knowing the orientation of a crystal lattice.
Zz.
I agree there many earlier evidence of the wave-like aspect of electrons.
But for kids it is not as illustrating as a two-slit experiment.
That's why I would like to know about wht has beed done that looks the closest to the optical Young slits experiments.
My purpose is not history it is more about pedagogy and fun.
Note also that low energies double slit experiments with electrons must be difficult.
I would also like to learn about this aspect.
Finally, it is not bad to look for experiences covering a broad range of parameters, not just the range that is the easiest to reach.
Clearly PEDE is routinely observed in electron microscopes.
I just realized there is currently an active thread on diffraction of macroscopic objects (https://www.physicsforums.com/showthread.php?t=186134)
I enjoyed very much the reference on C60 diffraction.
Actually, the question I was asking was a bit similar.
But instead of looking for macroscopic objects, I was more interrested in macroscopic slits.
My question was about electron diffraction observed with a macroscopic double-slits arrangement.
This implies of course a low energy electron beam, which can be difficult technically, specially for energies below the thermal level.
I am still interrested to know what has been done in this fields.
  • · Replies 36 ·
10K
  • · Replies 18 ·
  • · Replies 33 ·
  • · Replies 20 ·
  • · Replies 21 ·
