Vector calculus double integrals
The discussion focuses on calculating the volume V of the solid under the surface defined by the equation z = 4 - x² - y², over the rectangular region R where 0 ≤ x ≤ 1 and 0 ≤ y ≤ 2. The initial approach using the double integral ∫²₀∫¹₀ (4 - x² - y²) dx dy is confirmed as correct. The suggestion to switch to polar coordinates is deemed unnecessary, as polar coordinates are typically used for circular regions, not rectangular ones.
  • Understanding of double integrals in calculus
  • Familiarity with the concept of volume under a surface
  • Knowledge of Cartesian coordinates and their limits
  • Basic understanding of polar coordinates and when to use them
  • Study the application of double integrals in different coordinate systems
  • Learn how to set up limits of integration for various geometric shapes
  • Explore the use of polar coordinates for volume calculations over circular regions
  • Practice solving volume problems using double integrals with different functions
Students and professionals in mathematics, particularly those studying calculus, as well as educators teaching concepts related to double integrals and volume calculations under surfaces.
braindead101
Find the volume V of the solid under the surface z=4-x^2-y^2 and over the rectangle R consisting of all points (x,y) such that 0<=x<=1 and 0<=y<=2.
I have started, but am unsure if my approach is correct or not.
x = 4-x^2-y^2
[tex]\int^{2}_{0}\int^{1}_{0} 4-x^{2}-y^{2} dx dy[/tex]
is this correct?
or should i be putting it in polar coordinates, in which case how do i set up the limit of integration
[tex]\int\int_{\Omega} f(x,y) dA[/tex]
[tex]\Omega = \left\{ (x,y) | 0<=x<=1, 0<=y<=2 \right\}[/tex] ? is this right?
You're looking for the volume under the surface, within the bounds of the rectangle, right? Your first one is fine, though I think you meant to say f(x,y) = 4-x^2-y^2.
x = 4-x^2-y^2
I'm not sure why you would write that: z= 4- x2- y2, not x.
is this correct?
Of course, your first calculation is correct. In fact, the second formula,
is also correct- it's just a general statement of the formula for volume.
But there is no reason to change to polar coordinates. Polar coordinates would be appropriate if you were finding the volume over a disk.
  • · Replies 19 ·
