Solve Car Chase Problem: Find (Delta)t & Speed of Car B
  • Thread starter Thread starter Karma
    Car
The problem involves two cars, A and B, with car A accelerating at a constant rate before car B begins its pursuit. The task is to determine the time elapsed from when car B starts accelerating until it passes car A, as well as the speed of car B at that moment.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of graphs to visualize the problem, including position-time and speed-time graphs. There is an attempt to express the relationship between the distances covered by both cars algebraically. Questions arise regarding the use of time variables in the equations and the interpretation of the acceleration phases.
Some participants have shared their equations and reasoning, indicating progress in understanding the relationships between the variables. However, there is still some uncertainty regarding the application of time in the initial equations and how to proceed with the second part of the problem.
Participants are working under the constraints of a homework assignment, which may limit the types of resources or methods they can use to solve the problem. There is an emphasis on expressing the solution algebraically and checking answers through dimensional analysis.
Karma
Consider two cars A and B, initially side by side and both at rest. at t=0 car A begins to accelerate at a constant rate Aa, which continues for a a time Ta Until it reaches a speed Va, after which time it continues traveling at the constant speed Va. At the moment Car A reaches its cruising speed Va, car B takes off after Car A, accelerating at a constant rate Ab. at T=t* car B passes Car A.
C.) Determine the amount of time, (Delta)t, elapsed from the moment car B begins to accelerate to the moment it passes car A. What is the velocity of car B at the moment it passes car A? Note: You may use dimensional analysis to check your answers.
On a single graph i drew a Position Time Graph ... and Also i sketched a Speed-Time Graph... Me and my Roommates Have attempted to solve this problem for many hours... What can i do with the Graphs?
On my Speed-Time Graph... the constant acceleration and constant speed of Car A will be the same distance as the constant acceleration of Car B.
lol anyone??
Look up my thread... don't tell me...
Anyway, they want you to express it algebraically. The problem is quite simple; at Ta, car A covered 1/2Aa*Ta^2. This said, you have
1/2Aa*Ta^2 + Va*delta T = 1/2Ab*delta T^2.
It's simply a question of isolation delta T here.
Yes this was my formula as well.. but 1 question how come you don't use delta T for this first part of the equation ?
is it because in the beginning ...Ta-T0...is just Ta..? ... Ahhh I get it ...If that's right..
Werg can u help me with the 2nd part of the problem
So know that i got ... (delta)t= Aa*Ta^2/Ab ...
To find the velocity when Car b passes Car A... i used the equation ...
X(final)-X(initial)=((Vxi+Vxf)/2) * t
Xf-0= ((0+Vxf)/2) *t
Xf= Vxf/2 *t
2Xf=Vxf *t
2Xf/t = VxF
so i just sub My delta T in this equation?
  • · Replies 30 ·
  • · Replies 20 ·
