Solving Physics Problems: Max Height, Velocity & Horizontal Dist.
The discussion revolves around a physics problem involving projectile motion. A rock is thrown from a height of 14.1 m with an initial velocity of 31.6 m/s at an angle of 25 degrees above the horizontal. Participants are tasked with calculating the maximum height reached by the rock, the velocity just before it strikes the ground, and the horizontal distance from the building to the impact point.
  • Mixed
  • Participants explore various calculations related to the maximum height, velocity, and horizontal distance. There are attempts to clarify the use of angles in calculations and to verify the accuracy of derived values. Some participants express confusion regarding the setup and the equations used.
The discussion includes several attempts at calculations, with participants providing feedback on each other's work. Some guidance is offered regarding the use of conservation of energy and the correct application of kinematic equations. There is an ongoing exploration of different interpretations of the problem.
Participants note discrepancies in calculations and clarify the vertical displacement involved. There is mention of homework constraints and the need to adhere to specific problem-solving methods, which may influence the approaches taken.
Heat
A man stands on the roof of a building of height 14.1 m and throws a rock with a velocity of magnitude 31.6 m/s at an angle of 25.0 above the horizontal. You can ignore air resistance.
Calculate the maximum height above the roof reached by the rock.
Calculate the magnitude of the velocity of the rock just before it strikes the ground.
Calculate the horizontal distance from the base of the building to the point where the rock strikes the ground.
V^2 = V initial ^2 + 2a(x-xo)
The first part is the part, that I am getting stuck on, the other two parts of the question following it hopefully I will be able to do, as I encountered that type of problem before.
Anyways, my attempt:
Max height = unknown
Angle : 25 degrees
Vy = 0 m/s (at the highest point, Velocity is 0.
Vy initial is 13.35 m/s. ( I got this using 31.6 sin 25)
Height at beginning is 0. (Ignoring the fact that's the building is 14.1m)
0 = 13.35^2 + 2 (-9/8)(y-0)
-178.22 = -19.6y
y = 9.09 m
does this seem right?
In your initial statement of the question you say the angle is 25 degrees, but you use 75 in your calculation. Your approach works, though.
oops, my messy handwriting when working it out. does that seems right now..
Looks OK to me.
I thought this was going to be simple, but I was wrong:
my work:
V^2 = 13.35^2 + 2 ( -9.8) (9.10)
V^2 = -.1375:confused:
my work:
vertical displacement is -14.1m. not 9.10
remember that this is only vertical velocity... you'll need to get the total velocity after getting this part...
You can also use conservation of energy to do this problem.
ok I got Vy = 21.32.
i would think vx remains the same so
it would be
sqrt(21.32^2 + 13.35^2)
= 25.15
yes, but Vy = -21.32 (makes no difference for the magnitude)
it would be
= 25.15
But vx is not 13.35. that is the initial vy.
you are right, my messy handwriting at it again.
Vx is 28.64.
so the total velocity should be: 35.70
which is right.
I will now try to solve:
hopefully this is the same as a question I asked before regarding horizontal distance. :)
Vx is 28.64.
which is right.
yes. looks right. a faster way to solve the problem is with conservation of energy if you've covered energy...
I guess it will not work, as the previous was free falling with 0 initial velocity.
Here is what I did:
to find time it takes to drop I used the following:
-14.41 = .5(-9.8)t^2
t = 1.696
then I did
xfinal = 1.696/2 (28.64+28.64)
= 48.57
which is wrong :(
Here is what I did:
t = 1.696
then I did
= 48.57
which is wrong :(
I'm confused. Is this the same problem?
sorry, this is to find the horizontal distance from the base of the building to the point where the rock strikes the ground. In this same problem.
Use d = v1*t + (1/2)(-g)t^2
to get time.
ok I got time of 3.85s
using -14.1 = -31.6t -9.8t^2
now
it should be hopefully the following
xfinal = 3.85/2 (28.64+28.64)
= 110.16
seems awfully large.
No. it should be -14.1 = 31.6sin(25)t - 4.9t^2
now
= 110.16
I don't understand what you're doing here... once you have the time... the horizontal distance is just 31.6cos(25)*t
ok for t i got 3.54s
now when I plug in the equation provided for horizontal distance, I get 31.6cos(25) *3.54 = 101.38
which is correct.
also
prior to my equation before...what I did was the following
xfinal = time/2 (vox+vx)
which I retried and gave me the same thing, the problem I found out is that I had time wrong. :redface:
thank you for your help.
14K
10K
