| Thread Closed |
Minimal prime tuplets |
Share Thread | Thread Tools |
| Sep23-07, 11:05 PM | #1 |
Recognitions:
I was wondering if any nontrivial bounds for A008407 were known. This is the sequence of minimal width for k-tuplets of primes allowed by divisibility concerns. a(2) = 2 since n, n+2 could both be prime; n, n+1 isn't admissible since then either n or n+1 is even.
Clearly a(n+1) >= a(n) + 2, but practically speaking a(n) seems to grow superlinearly. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Sep24-07, 01:50 PM | #2 |
Recognitions:
Ah, it just hit me: an appropriate reformulation of the sequence is superadditive. Even better, A023193 is subadditive, so I can just use the best ratio with some additive constant as an absolute bound.
OK, here's what I have: A023193(n) <= floor(n*331/2467+33.1). This comes from the fact that A023193(4934) = 662, so 4934 consecutive numbers can't contain more than 662 primes as long as the smallest number in the range > 4934. So clearly every 4934n numbers can't contain more than 662n primes, since each of the n subintervals must be legal as well. The additive constant 33.1 is such that this holds for 1 <= n <= 4934, and so must hold for all n >= 1. (Also, checking shows that this actually holds even if the smallest number is less than 4934.) |
| Sep25-07, 08:57 AM | #3 |
Recognitions:
The purpose of the thread was to find an upper bound on the number of primes in a 'small' interval h, [itex]\pi(x)-\pi(x-h)[/itex]. Under the Riemann hypothesis we have
[tex]\left|\pi(x)-\pi(x-h)-(\operatorname{li}(x)-\operatorname{li}(x-h))\right|\le\frac{\ln x\sqrt x+\ln(x-h)\sqrt{x-h}}{8\pi}\approx\frac{\ln x\sqrt x}{4\pi}[/tex] for x-h > 3000, but we expect a large degree of cancellation. Using the above result we have [tex]\pi(x)-\pi(x-h)\le\frac{331h}{2467}+33.1[/tex] which may be tighter for small h or large x and is not dependent on the RH or any other unproved hypothesis -- though the k-tuple conjecture would mean that A02319 is a maximum rather than 'just' an upper bound. |
| Sep26-07, 04:14 PM | #4 |
Recognitions:
So equating the errors in the two methods, I get
[tex]\frac{331h}{2467}+33.1\approx\frac{\ln x\sqrt x}{4\pi}[/tex] which is [tex]h\approx2.372\ln x\sqrt x-4.44[/tex] So for large x, this method can be useful. Still, I wonder if there is a sublinear bound for this, which could greatly increase the useful range of the approximation. Has anyone seen something like this? Is there a book or a paper I could read? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Minimal prime tuplets
| a prime number which equals prime numbers | General Math | 10 | ||
| Has there been identical (N>2)-tuplets? | Biology | 5 | ||
| A formula of prime numbers for interval (q; (q+1)^2), where q is prime number. | Linear & Abstract Algebra | 0 | ||
| Prime Numbers in the Diophantine equation q=(n^2+1)/p and p is Prime | Linear & Abstract Algebra | 5 | ||
| Efficiency: prime test vs prime generator | Linear & Abstract Algebra | 14 | ||
