Photon Particle Wave or Straight?
  • Context: Graduate
  • Thread starter Thread starter jobyts
    Particle Photon Wave
The discussion revolves around the nature of photons, specifically whether they behave as particles or waves, and the implications of this duality on their speed and behavior. Participants explore theoretical aspects, misconceptions, and the historical context of terminology related to photons.
  • Some participants question whether photons travel as waves or if they move in a straight line with associated electric and magnetic fields oscillating.
  • One participant emphasizes that the distinction between particle and wave is not clear at the quantum level, suggesting the question may lack meaning.
  • A participant expresses a desire to explore whether anything within a photon can exceed the speed of light, proposing that the photon’s wave-like behavior could imply faster speeds due to oscillations.
  • Another participant clarifies that when discussing waves, it is the electric and magnetic fields that oscillate, not the photon itself, challenging the notion of a photon riding on a wave.
  • Concerns are raised about the interpretation of "spin" in quantum mechanics, with a participant arguing that it does not imply physical spinning and should be understood in a broader context.
  • One participant argues against the concept of wave-particle duality, stating that photons do not consistently behave as either classical particles or waves, and warns against extending classical analogies too far.
  • There is mention of the absence of a medium for photons, which complicates the analogy of waves and raises questions about the assumptions underlying discussions of faster-than-light phenomena.
Participants express differing views on the nature of photons, with no consensus reached regarding their behavior as particles or waves. The discussion includes both support for and challenges to established concepts, indicating ongoing debate.
Participants highlight limitations in understanding related to terminology and the implications of quantum mechanics, particularly regarding the definitions of wave and particle behavior. There are unresolved questions about the speed of photons and the nature of their spin.
jobyts
Does the photon particle actually go like a wave, or,
does the photon go straight and there is a magnetic/electric field that is attached to the photon goes like a wave?
Thanks,
.joby
Wikipediate this. Don't wish to be rude- but this is one of the most oft asked questions in physics. Not that it's a bad question- it's just been covered to death by real experts.
The whole point of wave- particle is that at the level, the distinction between "particle" and "wave" is simply not as clear as at "macro" levels. That is, there simply is no clear difference between them so the question itself has little meaning.
The intention for my original question was just to give an introduction to the actual question I have here. I was trying to see, within the photon itself, is anything goes faster than the speed of photon.
If the photon actually goes like a wave, the speed of photon should be faster that the Michaelson's experiment result, because the photon also did some up and down movement along the path.
Even the answer is the second one (the fields around the photon goes like a wave), there should be some points (mathematical) in the photon that goes faster than the well known value for the speed of light. I just read the photons spin. So, an outer point on a photon should be faster (linear velocity + angular velocity) than the speed of light (only the linear velocity), right?
You have a lot of misconception here.
First of all, when we talk about a "wave", we need to be clear on what is "waving". In electromagnetic wave, it is the electric and magnetic field vector (or amplitude) that is oscillating. A photon carries such vectors. However, it is not as easy to describe it when you only have ONE photon. So no, the photon doesn't sit on a wave the way you think a buoy or water molecules oscillate with the wave. That is a totally wrong picture.
Secondly, a "spin" quantum number has nothing to do with anything spinning. This applies to photon, electron, neutron, proton, etc... You should understand the physics BEYOND just what the "name" implies in ordinary language. The word spin is only significant historically. It has nothing to do with anything spinning.
Zz.
Waves always act like waves, by definition. Classical particles always act like classical particles, by definition. Photons do not always act like waves, nor do they always act like classical particles. Therefore they are neither. The "wave-particle duality" is an oxymoron, for it implies photons really are waves and they really are classical particles.
I'm not just pointing out a semantic issue here. It is important that we not think of photons as actual classical particles, or as actual waves. This is so we don't extend the analogy too far. Doing so may cause us to presume a falsehood, and also to miss what they really are.
For example, waves travel in a medium, photons do not. Since there is no medium, we must be careful not to extend the analogy and imagine, for example, somehow changing that medium in some way in order to change the speed of those "waves". There are some possibilities for faster-than-light things going on, but they should not be based on an assumption that there is an aether.
  • · Replies 18 ·
  • · Replies 36 ·
10K
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 18 ·
