Integrating Difficult Integrals: (1-x^2)(f ''(x)) & (a^2-x^2)(f ''(x))
  • Context: Graduate
  • Thread starter Thread starter Falcon
    Integral Interesting
The discussion revolves around the integration of two challenging integrals involving the second derivative of a function, specifically (1-x^2)(f ''(x)) and (a^2-x^2)(f ''(x)). Participants explore various approaches to solve these integrals, including integration by parts and substitutions, while grappling with the implications of not knowing the function f directly.
  • Homework-related
  • One participant expresses confusion over the integrals and notes that the professor did not specify f''(x) directly, which complicates the problem.
  • Another participant suggests separating the integral into two parts, proposing an integration by parts approach for the integral of (1-x^2)(f''(x)).
  • A different participant argues against separating (1-x^2) and provides a detailed integration by parts method, leading to a more complex expression that still cannot be evaluated without knowing f.
  • There is a mention of a potential advantage in using (a^2-x^2) over (1-x^2) due to the simplification of terms when evaluated at the limits.
Participants present multiple approaches to the integrals, with no consensus on a single method or solution. The discussion remains unresolved regarding the best approach to take.
The discussion highlights the challenge of integrating expressions involving f''(x) without knowing the function f itself, which introduces uncertainty in evaluating the integrals.
Falcon
Here's a pretty difficult integral that our prof threw at us a couple days ago... left the whole class a little dumbfounded. I wish I had symbols to use (such as the ones that a lot of the pros on this site use)... but I'm sure you'll be able to understand.
Integrate (from a to b) the following (1-x^2)(f ''(x)) dx
He went on to say that if we couldn't get that, perhaps we should look at this one:
Integrate (from -a to a) the following (a^2-x^2)(f ''(x))
(he suggested IBP)
I think what threw most people off was how he knew what f''(x) was without identifying it directly.
Thanks for everyones help in advance!
-Chris
I can't say I have ever done anything like that. However would it not be fairly easy to say:
[tex]\int_b^a (1-x^2)f''(x) dx = \int_b^a f''(x) dx - \int_b^a (x^2)f''(x)dx[/tex]
[tex]\left[ f'(x) \right]_b^a - \int_b^a (x^2)f''(x)dx[/tex]
And apply by parts on the remaining integral. That's just a guess :confused:
There's no reason to separate the (1- x2).
Let u= 1-x2 and dv= f"(x)dx
Then du= -2xdx and v= f '(x)
so the integral becomes [itex](1-x^2)f'(x)\|_a^b+ 2\int_a^bxf'(x)dx[/itex]
To do that second integral let u= x, dv= f'(x)dx so
du= dx and v= f(x). The second integral becomes [itex]xf(x)\|_a^b- 2\int_a^bf(x)dx[/itex].
The entire integral is [itex](1-b^2)f'(b)-(1-a^2)f'(a)+ 2bf(b)-2af(a)- 2\int_a^bf(x)dx[/itex]
The "advantage" of using a2-x2 instead of 1- x2 is that the "(1-a2) term is 0 and we have only [itex](a^2-b^2)f'(b)+ 2bf(b)-2af(a)- 2\int_a^bf(x)dx[/itex].
Of course, we can't evaluate that last integral precisely because we don't know f itself.
ahhh.. thank you both very much for your help!
[bows to HallsofIvy]
very much appreciated :)
  • · Replies 17 ·
