Is the Solution to the Annuity Differential Equation Correct?
The discussion centers on solving the differential equation S' = k + rS, which models the accrued interest on an annuity with regular deposits. The proposed solution is S(t) = (So + k)e^rt - k, where So is the initial amount, k is the regular deposit, and r is the interest rate. Clarifications confirm that k remains a constant deposit amount, and the equation should not be modified to include k(t) as a variable dependent on time. The correct approach maintains k as a fixed value, leading to the conclusion that the differential equation should not be altered to S' = kt + rS.
  • Understanding of differential equations, specifically first-order linear equations.
  • Familiarity with the concept of annuities and regular deposits.
  • Knowledge of exponential functions and their properties.
  • Basic grasp of initial conditions in differential equations.
  • Study the derivation of solutions for first-order linear differential equations.
  • Learn about the financial mathematics of annuities and their formulas.
  • Explore the implications of varying deposit amounts in differential equations.
  • Investigate the use of Laplace transforms in solving differential equations related to finance.
Mathematicians, finance professionals, students studying differential equations, and anyone interested in the mathematical modeling of annuities.
wakko101
I'm trying to figure out the solution to a differential equation that describes the accrued interest on an annuity - rather than a lump sum at the beginning, we're dealing with multiple and regular deposits. The prof implied that we would have to solve for the dif eq'n
S' = k + rS
where k is the deposit, r the interest rate and S(t) the amount of money accrued at time t. I think I've solved for this particular equation (with intinial condition S(0) - So) which is
but I have two questions. First, this doesn't seem right in terms of the fact that I'm subtracting k at the end there. And secondly, should k somehow be in terms of t as well (i.e. k(t) since the deposits are regular, i.e. at time t, I will have made k(t) deposits?)
Any insight would be appreicated...
Thanks,
W.
S' = k + rS
Look what happens when t= 0. e^0= 1 so S(0)= S0+ k- k. that's why you have to subtract off k- initially, you don't deposit k dollars at t= 0.
No! k is the amount of money you deposit each month and that is a constant. At time t (months) you will have kt (k times t) not k(t) (k of t).
Thanks,
W.
thanks! but, another question, then...does that mean I have to start with the dif eq'n
S' = kt + rS ?
Cheers. =)
