| Thread Closed |
Proving kernel of matrix is isomorphic to 0 eigenvalue's eigenvectors |
Share Thread |
| Sep25-07, 03:48 PM | #1 |
I want to prove that the eigenvectors corresponding to the 0 eigenvalue of hte matrix is the same thing as the kernel of the matrix. 2. Relevant equations A = matrix. L = lambda (eigenvalues) Ax=Lx 3. The attempt at a solution Ax = 0 is the nullspace. Ax = Lx Lx = 0. L= 0. the eigenvectors corresponding to the 0 eigenvalue are the same as the nullspace. Is this a sufficient enough proof? |
| Sep25-07, 08:57 PM | #2 |
Recognitions:
No, it's not. Maybe you have the right idea, but what you've written down doesn't make a lot of sense.
The nullspace is {x : Ax = 0}. Can you write down what the set of eigenvectors corresponding to zero is? |
| Sep26-07, 01:38 AM | #3 |
Isn't the the set of eigenvectors which correspond to the 0 eigenvalue?
| Sep26-07, 02:26 PM | #4 |
Recognitions:
What is the definition of the kernel of a matrix? What is the definition of the set of eigenvectors of a matrix with eigenvalue zero? Aren't they trivially the same?
| Thread Closed |
Similar discussions for: Proving kernel of matrix is isomorphic to 0 eigenvalue's eigenvectors
| [SOLVED] Kernel and image of a matrix A | Calculus & Beyond Homework | 4 | ||
| 3 x 3 matrix eigenvectors | Calculus & Beyond Homework | 11 | ||
| Eigenvectors of a 3x3 Matrix | Precalculus Mathematics Homework | 11 | ||
| Eigenvectors and using them in matrix algebra. | Linear & Abstract Algebra | 1 | ||
| Diagonalize a Matrix A - Normalize eigenvectors | Linear & Abstract Algebra | 6 | ||
