| Thread Closed |
Is every point of every closed set E subset of R^2 a limit point of E? |
Share Thread | Thread Tools |
| Sep26-07, 04:21 AM | #1 |
If E is subset of R^2, then is every point of every closed set E, a limit point of E? 2. Relevant equations 3. The attempt at a solution I think the answer is yes. Consider E = { (x,y) | x^2 + y^2 <= r^2} , where r is the radius. Consider a point p that belongs to E, then p shall be a limit point if the intersection of Ne(p) ( that is neiborhood of "p" with "e" as radius) and set E has another point "q", such that p and q are not the same. Now, we know that the Ne(p) = circle with radius "e" around "p". Since "p" is an internal point the intersection of this circle with that of E, (another circle) shall have several points other than "p". Hence, all points in E are limit points. any comments? Thanks. |
| Sep26-07, 05:52 AM | #2 |
One example does not a proof make!
But one counter-example does. Consider the set {[itex](x,y)| x^2+ y^2\le r[/itex]}[itex]\cup[/itex] {[itex](0, r+1)[/itex]} Is (0, r+1) a limit point of that set? Look up "isolated point" in your text book. |
| Sep26-07, 12:45 PM | #3 |
What does that mean? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Is every point of every closed set E subset of R^2 a limit point of E?
| Why triple point of water is higher than freezing point | Classical Physics | 7 | ||
| A point of a closed convex set? | Calculus & Beyond Homework | 2 | ||
| def'n of Limit Point? and limit. | Calculus | 6 | ||
| [SOLVED] Why zero slope limit is point particle limit? | Beyond the Standard Model | 1 | ||
| Calculating point X on the Golden Spiral knowing a point and a distance | Calculus | 0 | ||
