Proving Matrix Equality with Inverse Properties
The discussion revolves around proving the equality of two matrices, X and Z, given that XY = I and YZ = I for n×n square matrices X, Y, and Z. Participants explore the implications of these equalities and the properties of matrix inverses in the context of linear algebra.
  • One participant proposes a method to show X = Z by manipulating the equations XY = I and YZ = I, questioning if the same logic applies when Y is on different sides of X and Z.
  • Another participant challenges the initial approach, suggesting that if XY = I, then YX = I might also hold, which could be relevant to the proof.
  • A different participant claims to have solved the problem by expressing Y in terms of X and substituting it into the second equation, concluding that Z = X.
  • Another contribution outlines a reasoning path using the properties of the identity matrix and the relationships between the matrices, while noting the need to prove the existence of inverses.
  • A later reply acknowledges the oversight regarding the existence of inverses and expresses agreement with the previous participant's reasoning.
Participants express differing views on the validity of certain steps in the proof, particularly regarding the manipulation of matrices and the existence of inverses. No consensus is reached on a definitive method to prove X = Z.
Participants note the importance of the existence of inverses in their arguments, indicating that the proof may depend on this condition being satisfied.
ConeOfIce
The question is: Suppose one has n×n square matrices X, Y and Z such that
XY = I and Y Z = I. Show that it follows that X = Z.
Now if this were XY and ZY, I would just say that:
XY=ZY -> XY-ZY=0 ->Y(X-Z)=0 -> X-Z=0 -> X=Z.
I am wondering that since the Y is on different sides of the Z and X this still holds? Thanks!
I don't think you can just pull the Y out like that.
If I recall correctly, if XY = I, then doesn't YX = I aswell? If this is true perhaps you could encorporate it into your proof somehow.
Actually I think I just figured it out.
X^-1 Y =X^-1 I -> Y=X^-1
then sub that in for Y in the other equation
X^-1 Z = I
XX^-1 Z = X
Z=X
Thanks for your help!
it goes like this: XY = I so XYZ = IZ = Z.
but YZ = I too, so XYZ = XI = X. so X = XYZ = Z.
the problem with your argument is that there is no X^-1 unless yoiu prove this problem.
but if yu are careful, yu can use the fact that X = the left inverse of Y and Z = the right inverse of Y.
Oh, I forgot the inverses don't always exist...it has been a bit since I have done and linear algebra work. Your solution makes perfect sense, thanks!
  • · Replies 0 ·
  • · Replies 26 ·
  • · Replies 23 ·
