Calculating Center of Mass for a System of Spherical Masses on the x-axis
The problem involves calculating the center of mass for a system of three spherical masses positioned along the x-axis. The masses are specified as 5M at the origin, 2M at x = +12.0 units, and M at x = -8.0 units, with a rigid rod connecting them, which is assumed to have negligible mass.
  • Exploratory, Assumption checking
  • Participants discuss the appropriate formula for calculating the center of mass and question the correct application of the values provided. There is a focus on ensuring all masses and their respective positions are accounted for in the calculation.
Some participants have offered guidance on the formula to use, while others are exploring the implications of unit systems and the correctness of the initial calculations. There is a lack of consensus on the final answer, with differing interpretations of the units involved.
There is a mention of potential confusion regarding the unit system being used, as well as a miscount of the number of masses in the initial equation setup.
psruler
Hi, here is the problem:
Imagine three spherical masses all fixed on the x-axis: mass 5M at the origin, mass 2M at x =+12.0 units, and mass M at x = -8.0 units, all connected by a rigid rod whose mass can be ignored. At what position along the x-axis is the center of mass of the system located?
is this the correct equation? if so, i don't know where to plug in the numbers.
x = (m1x1 + m2x2)/ m1+m2
Thanks!
Yes.
Take a guess. You got 2 sets of values in the given and two sets of x and m in your equation. What makes sense?
cookiemonster
i got 2units as the answer. is that correct?
Oops.
You got 3 sets of values and 3 pairs of x and m. Your formula should be
[tex]\bar{x} = \frac{m_1x_1 + m_2x_2 + m_3x_3}{m_1 + m_2 + m_2}[/tex]
Sorry. I didn't catch that third value the first time.
2 "units" is not the correct answer. You should be getting something in units of meters.
cookiemonster
Actually the answer is 2 "units". Where does it say we are working within the SI system, or any other unit system for that matter?
I could have sworn I read "meters" in that post last night! I must have been tired. =\
cookiemonster
  • · Replies 25 ·
