| Thread Closed |
Output Flow Calculation |
Share Thread | Thread Tools |
| Sep27-07, 12:55 PM | #1 |
An entire system is filled with liquid.
At the top (30 feet) is a 2 gallon container, connected to a tube (1.25" ID) for 14 feet, connected to a tube (1.00" ID) for 10 feet, then split with tees to 8 valves (.75" ID) and tubing (1.00" ID). |.............| |.............| |....2.g.....| |.............| .\_........_/ ....\...../ .....|...| .....|...| 14 feet (1.25" ID) .....|...| .....|...| .....|...| .....|...| ......\../ .......|| .......|| .......|| 10 feet (1.00" ID) .......|| .......|| .......|| ......//\\ =O=O=O=O= valves (sorry, the diagram on paper looks a lot better) What is the flow rate at one opening if all valves are opened? what is the flow rate at one opening is one valve is opened? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Oct16-07, 10:44 PM | #2 |
is it an assignment , obviously it looks like an asignment
| Thread Closed |
| Thread Tools | |
Similar Threads for: Output Flow Calculation
| Java project output problem. Can't output objects from a method. | Engineering, Comp Sci, & Technology Homework | 0 | ||
| [SOLVED] Simple volume flow rate calculation | Introductory Physics Homework | 2 | ||
| Calculation of Flow rate | Mechanical Engineering | 1 | ||
| On numerical calculation of Lift Force via Potential Flow | Mechanical Engineering | 0 | ||
