Thread Closed
What's the Current of the Potential Difference?
Share Thread
Sep28-07, 02:13 AM   #1
A potential difference is applied between the electrodes in a gas discharge tube. In 2.0 s, 3.3*10^16 electrons and 1.2*10^16 singly charged positive ions move in opposite directions through a surface perpendicular to the length of the tube. What is the current in the tube?
2. Relevant equations
I = C/T
3. The attempt at a solution
I reason that the current is in the direction of the movement of the positive ions:
I = { 1.2E16 positive ions * 1.60E-19 C / 1 positive ion } / 2 seconds
= 9.6E-4 A
However the above is not the correct solution, and neither is when I use 3.3E16, the number of electrons. I think I'm not understanding a concept here.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Sep28-07, 03:50 AM   #2
Recognitions:
Homework Helper Homework Help
You know, current is "flowing" in the positive charge direction, i.e opposite direction of electron motion. So that the total flow of charge is:
deltaQ = (1.2*10^16 + 3.3*10^16)*1.602*10^-19 C
Draw a picture of electrons moving towards one end of the tube, and positive ions towards the other. Then draw arrows that represent the current assoiciated with each "charge-type", then add :)
Then divide by 2sec; then the average current is: I_avg = 0.0036 [C/s = A]
Sep28-07, 04:10 AM   #3
This question is ambiguous.
When those positive ions hit the cathode, they'll pick up electrons and start moving in the opposite direction. We might presume that since it says they are singly charged, that each ion carries two electrons each trip.
What is not made clear, is whether the value specified for electrons moving from the cathode to the anode includes the electrons that are carried by negative ions.
If the value specified for electrons includes those carried by negative ions, then simply consider the electron flow that is specified, and ignore the statement about the ions.
If the value specified for electrons does not include those carried by negative ions, then double the ion flow (because each ion carries two electrons each trip) and add the electron flow to get the total flow.
Thread Closed
Similar discussions for: What's the Current of the Potential Difference?
Thread Forum Replies
[SOLVED] current and potential difference, simplifying circuit diagrams Introductory Physics Homework 3
Current and Potential difference in a circuit Introductory Physics Homework 13
Potential difference and current Introductory Physics Homework 1
Potential Difference, current, and resistance Introductory Physics Homework 3
EMF, Voltage, Current, Potential Difference etc. Introductory Physics Homework 6
