A question regarding a graduate school
The discussion revolves around the impact of undergraduate research experience and publications on graduate school admissions. Participants explore various aspects of how research involvement, particularly in relation to the field of intended graduate study, influences acceptance chances.
  • Some participants propose that having published research significantly improves chances of getting into graduate school.
  • Others argue that while research experience is beneficial, it does not guarantee acceptance into graduate programs.
  • One participant questions the relevance of being published in a field unrelated to the intended graduate field, suggesting it may not matter much.
  • It is noted that the timing of publication relative to application deadlines can complicate the impact of research experience on admissions.
  • Some participants emphasize that having a strong Honors Thesis can improve chances, but it is not a definitive factor.
  • There is a discussion about the perception of research experience and its varying significance depending on the context of the application.
Participants express differing views on the extent to which undergraduate research and publications affect graduate school admissions. There is no consensus on the definitive impact of these factors, and the discussion remains unresolved.
Participants acknowledge the limitations of their claims, particularly regarding the timing of applications and the nature of research experience. The discussion highlights the uncertainty surrounding how much research experience truly influences admissions outcomes.
haplo
Just a hypothetical question. If you undergrad and did the research that is published, how much does it significantly improves you chances of getting into graduate school.
I think it pretty much guarantees.
i highly doubt that. getting on a paper is not that difficult
That means you are good :)
Does it matter much if you're published in a field unrelated to your intended graduate field?
i.e. paper is on concrete creep testing, intending on doing thermal-fluids in grad school
sorry to commandeer the thread
no it means i go to a research school
Ok. Going to research school makes you good in research.
No it does not, Timur. And it certainly does not guarantee acceptance!
Haplo and Ekrim, all research experience is beneficial for your grad school application, regardless of the area of research. If the area of research experience is the same as the area you intend to pursue, all the better, but doesn't hurt to have experience in other areas. As Ice said, it's not very difficult to get your name on a paper. If you're first author on the paper, that's a bit more impressive.
In short, I don't think there's a way to quantify how much it improves your chances of acceptance, if any. It never hurts, and it will most likely help by showing that a) you have some research experience and skills, b) you had the motivation to join and research project, and c) you possibly have some project leadership or technical writing experience.
Good luck with the application process!
I disagree, I think if you did a good Honors Thesis type paper, it does improve your chances at grad school, it doesn't gurantee it by any means, but it certainly helps.
The problem with most publications and honors thesis is that you have to submit your application to grad school before they are published or completed. Unless you took a break between senior year and grad school.
Good point, but the person you are doing your Honors Thesis under will usually their letters in mid to late November, by that time they should have a good idea of how you are doing in your Honors Thesis. Believe me, just because there is no immediate payoff does not mean it's beneficial. Bottom line? You are better off with some sort of research paper than without.
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 22 ·
