Thread Closed
Heat needed to evaporate water
Share Thread Thread Tools
Sep29-07, 02:56 PM   #1
A vessel of 1m^3 volume is half filled with water. The pressure inside the vessel is 2bar.
Steam tables are given
2. Relevant equations
How much heat is needed to completely evaporate the water?
3. The attempt at a solution
I can find the final enthalpy by finding h(g) at 2 bar. But how do you find the initial enthalpy?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Sep29-07, 04:14 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Does the vessel have a pressure relief valeve that maintains the pressure at 2 bar? If not, the pressure is going to increase linearly with the volume of water boiled off. This part is easy to calculate. As for your steam tables, I'm not sure exactly what you are looking at (different steam tables have different sets of data and use different forms of presentation). There are 3 relevant enthalpies: the enthalpy of water at 100C, the enthalpy of saturated steam, and the enthalpy of vaporization (the difference between the previous 2 numbers).
Have you written down the question completely, and exactly as it was given to you? If not, please post the question EXACTLY as it was given to you. What is the temperature of the water in the vessel?
Sep29-07, 11:50 PM   #3
I quoted this question from a thermodynamics past paper. This is all that is given.
It is a short answer question ie. given only couple of lines to answer.
Thread Closed
Thread Tools
Similar Threads for: Heat needed to evaporate water
Thread Forum Replies
[SOLVED] Quantity of Heat/Specific Heat Water+Iron Introductory Physics Homework 3
Heat that needed Introductory Physics Homework 2
Heat that are needed Introductory Physics Homework 4
amount of watts needed to heat water Introductory Physics Homework 5
Does alcohol really help to evaporate water? General Physics 5
