Finding Tension and Acceleration: Coefficient of Friction Problem
  • Thread starter Thread starter splac6996
    Tension
The problem involves a 2.0 kg block on a table with a coefficient of kinetic friction of 0.260. Participants are discussing how to find the tension in the rope and the acceleration of the system involving multiple weights.
  • Mixed
  • Participants are exploring the setup of free body diagrams and force equations for the blocks involved. There is discussion about the relationship between tension and acceleration, as well as the forces acting on each weight. Some participants express uncertainty about how to incorporate the forces into their equations.
There is ongoing exploration of the equations needed to solve for tension and acceleration. Some participants have provided guidance on ensuring consistent force directions and the need for multiple equations due to the presence of multiple unknowns. However, there is no explicit consensus on the final approach yet.
Participants note that the information provided may be insufficient for a complete analysis, particularly regarding the forces acting on the weights and the relationships between them.
splac6996
The coefficient of kinetic friction between the 2.0 kg block in figure and the table is 0.260.
I set up my free body diagram and from there my force equations for all three systems I believe that I need to find an equation for tension and from that find accelaration by doing some substitution but I am getting stuck.
You haven't given us enough information to tell where you are getting stuck. What's the total force on each object in terms of the unknown tension T? Keep all of the forces going in the same direction along the rope. Finally remember all of the accelerations are equal.
That is where I am getting stuck I now that the only reactions on the 1.0kg weight and the 3kg weight is Tension and mg but I am not sure how to use that in my equation for my 2.0kg weight which is
[tex]\Sigma[/tex]Fx=2T-fk=ma
[tex]\Sigma[/tex]Fy=N-mg=0
The two tensions acting on the 2kg weight are likely not equal. You'll get three unknowns (the two unknown tensions and the acceleration). Luckily you have three objects to do a force balance on so you will get three equations.
SO SHOULD MY EQUATION FOR ACCELERATION LOOK LIKE THIS
(T1-T2-fk)/m=a
YES BUT BE SURE YOU GET THE FORCE DIRECTIONS CONSISTENT. Like all in the same direction along the rope.
thanks for walking me through that
  • · Replies 18 ·
  • · Replies 47 ·
