Thread Closed
Force on a pully system
Share Thread Thread Tools
Sep30-07, 10:13 PM   #1
A block of mass m1 = 4.00 kg on a frictionless inclined plane of angle 30.0° is connected by a cord over a massless, frictionless pulley to a second block of mass m2 = 2.40 kg hanging vertically (Fig. 5-41).
Figure 5-41
(a) What is the magnitude of the acceleration of each block?
F=ma; F1=M1g F1 = 23.5N F2=M2Gsin(30)=19.6N Ax1=3.9N/4kg=.975m/s^2 thats wrong, the same for the other mass which I just subbed the 4 with the 2.4kg
(b)What is the tension in the cord?
the two forces combined 19.6+23.5=43.12N
also wrong
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep30-07, 10:18 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
There are two forces acting on m1, a component of m1*g acting along the incline and the tension T. There are also two forces acting on m2, m2*g and T. Both have the same acceleration a, so write F=ma for each and solve for a and T.
Sep30-07, 10:29 PM   #3
I understand that, but that still yeilds a force of 3.9N right, in negative X I have M1gsin30 and in positive I have M2g so, Fx1= M2g - M1gsin30 =3.9N and divided by mass, thats still .975m/s^2 right?
Sep30-07, 10:40 PM   #4
Recognitions:
You are just adding together the gravitational forces. I don't see any tension force in there. Write down the sum of the forces on each object and then equate them to m*a. Call the tension T. It's pulling up on both objects. There are two unknowns in the problem, the tension and the acceleration. You need an F=ma equation for both objects to get two equations to solve for them.
Sep30-07, 10:53 PM   #5
okay I got you, I need to put T in there from the start, I just supposed T was the difference in the forces.
Thread Closed
Thread Tools
Similar Threads for: Force on a pully system
Thread Forum Replies
Force System Introductory Physics Homework 3
force couple system Introductory Physics Homework 1
Force-Couple System Introductory Physics Homework 1
if there is a net torque on a system does that mean there's net force on the system Introductory Physics Homework 1
Pully Problem, Force/Tension Introductory Physics Homework 2
